Re-ringing with block in car.
Old Jan 20, 2010 | 04:56 PM
PariahBoardshop's Avatar
Default Re-ringing with block in car.
I am curious as to how easy this is, after removing the head I was told you can access the rings through the top of the block. When a cylinder is at TDC (head off) how far above the block does it sit?
I searched a bit and couldnt find anything specific to these sorts of questions. Thanks in advance.
Old Jan 20, 2010 | 05:55 PM
hatcht9x's Avatar
Default Re: Re-ringing with block in car.
you would need to pull the assembly out through the bottom..
Old Jan 20, 2010 | 06:32 PM
non-VTEC's Avatar
what assembly u talking about?
to the original poster......you need to remove the pistons from the engine to install new rings. this requires you to remove the oil pan, oil pick-up tube, windage tray. then you have to remove the rod nuts/bolts from the rods and push the whole rod/piston out of the engine block.
its not a job for someone who is not experienced....
Old Jan 20, 2010 | 06:45 PM
hatcht9x's Avatar
the assembly I was referring to is the crank/rods/pistons..
Old Jan 20, 2010 | 07:26 PM
So the crank will stay in but you can release the piston/rod with the block in the car.
Thanks
Old Jan 20, 2010 | 07:37 PM
zedron's Avatar
Crank can stay in. Just remove the oil pan, windage tray and pickup, and then remove rod bolts and caps and push piston up out of block. Upon reinstallation make sure to position the ring gaps in the correct position or you may get excessive blowby.
kingofnothing
14
Jan 6, 2009 03:08 PM
UncivilB18C
Jan 30, 2008 01:36 PM
Westrock2000
Mar 30, 2002 04:31 PM
MXPX
Jun 30, 2001 03:14 AM
