wtt 99 civic ex for integra
Old Jan 20, 2010 | 02:44 PM
swapped5993's Avatar
Post wtt 99 civic ex for integra
im looking to trade my black two door 1999 honda civic ex 5 spd with 170,xxx rebuilt at 158,xxx all stock except 16 inch rota slipstreams (gunmetal with a polished lip) for a 1994-2001 acura integra two door 5spd. open to all trades. The car runs extremely well, no smoke, no problems, welcome to come test drive. will update new pics tomorrow.
Originally Posted by UNDERGROUNDAUTOSALON
I can vouch for this car, It was my fathers car before it was sold to Jesse. CAR WAS ADULT OWNED AND DRIVEN BY MY 50 YR OLD FATHER UNTIL 12K AGO..... I did the maint and stock rebuild on it 12k ago, Don Drury of Drury Automotive did the machine work...I have 7 years Honda dealership exp., 1 year Ford dealership exp, and 1.5 years body shop exp. Don has over 40 years machine shop exp....
The car was involved in a small collision approx. 12k miles ago, car was tapped in the rear and pushed into the car in front of it, it wasnt bad at all, most parts were Keystone OEM replacement parts....put the front end parts on and never painted them, they are black primer that they come in, Car is also black, Car needs a paint job!!!!!
motor is original D16Y8 SOHC VTEC, trans is original 5-speed, car had the following new parts and work done approx 12k ago, OEM parts are just that real Honda OEM parts:
BRONZE EXHAUST VALVE GUIDES
HEAD STRAIT EDGED/RESURFACED/PRESSURE TESTED
3 ANGLE VALVE JOB
VALVE LASH SET
OEM HEADSET
OEM HEAD BOLTS
OEM TIMING BELT
OEM WATER PUMP
NEW OEM TIMING COVERS
OEM AIR FILTER
OEM FUEL FILTER
OEM DIST. CAP AND DIST. ROTOR
OEM NGK PLUGS
OEM PLUG WIRES
AFTERMARKET ALUMINUM RACE RADIATOR
AFTERMARKET CONDENSOR
OEM RADIATOR HOSES (upper & lower)
OEM KNOCK SENSOR
CATCO OEM REPLACEMENT CAT
probaly more just cant remember right now
Body work:
AFTERMARKET HOOD (oem style)
AFTERMARKET FENDERS (oem style)
AFTERMARKET FRONT BUMPER AND REAR BUMPER (oem style)
AFTERMARKET HEADLIGHTS (oem style)
OEM HOOD LATCH
AFTERMARKET L.F. WINDOW MOTOR/REGULATOR
OEM MUFFLER
OEM RADIATOR OVERFLOW
Old Jan 20, 2010 | 02:47 PM
k20powered's Avatar
Default Re: wtt 99 civic ex for integra
is it swapped! check my
thread
Old Jan 20, 2010 | 03:04 PM
no its all stock except for rota slipstreams.
Old Jan 20, 2010 | 03:18 PM
UNDERGROUNDAUTOSALON's Avatar
3 ANGLE VALVE JOB
VALVE LASH SET
OEM HEADSET
OEM HEAD BOLTS
OEM TIMING BELT
OEM WATER PUMP
OEM AIR FILTER
OEM FUEL FILTER
OEM NGK PLUGS
OEM PLUG WIRES
OEM KNOCK SENSOR
Body work:
OEM HOOD LATCH
OEM MUFFLER
Old Jan 20, 2010 | 09:34 PM
Bartman201's Avatar
pics
Old Jan 21, 2010 | 05:11 AM
I will add pics today when i get home.
Old Jan 21, 2010 | 09:23 AM
here are some pictures i took of the car today, sorry its dirty in the pictures.
Old Jan 21, 2010 | 11:09 AM
i just noticed that in the one picture there is something on the trunk that is not a scratch. must be the way i took the picture.
Old Jan 21, 2010 | 11:28 AM
here are pictures of the car after the accident. as you can see the damage was minimal.
Old Jan 21, 2010 | 11:30 AM
heres some more pictures. once again im sorry the car is dirty.
Old Jan 23, 2010 | 07:51 AM
morning bump!
cmartdude54
May 19, 2017 07:14 PM
slostjoe
Mar 1, 2011 01:16 PM
