Transmission & Drivetrain Gearboxes, Differentials, Clutches
92 GSR tranny hard to get into 2nd gear!!
Old Jan 20, 2010 | 01:30 PM
092eg6's Avatar
Default 92 GSR tranny hard to get into 2nd gear!!
it's my buddys tranny, the tranny cant get into 2nd gear when u shift at high rpms at all, untill the rpm drops down to like 3-4K then it makes a grinding noise before u can force it in.... any idea what can be wrong here?
Old Jan 20, 2010 | 02:42 PM
egjdmcivichatch's Avatar
Default Re: 92 GSR tranny hard to get into 2nd gear!!
synchros.... most common problem with gsr trannys including mine.. id start there.
Old Jan 20, 2010 | 03:30 PM
Alex M.'s Avatar
Just started to have the same issue with mine today. If I shift into second above 3k RPM's , I get the same ginding noise, f*****g sucks.
Old Jan 21, 2010 | 01:38 PM
Aquafina's Avatar
Strike 1.
Replace the 1/2 sleeve set, possibly CS 2nd gear as well.
Old Jan 21, 2010 | 10:38 PM
strike 1?? ^^^
Old Jan 21, 2010 | 10:40 PM
Aquafina's Avatar
Yep.
Old Jan 22, 2010 | 09:41 AM
whats that supposed to mean?
Old Jan 22, 2010 | 05:32 PM
092eg6's Avatar
hahahah not even close to being the syncros, the shift linkage joint where it connects to the tranny had too much play, the bolts were loose, i tighten up the bolts and bamm it shifts like a champ!! thanks for all the advice.
Old Jan 22, 2010 | 06:14 PM
kool that u found out what it was! but i never said that was the actual case just that its a common problem and u should start there... and from what u put down it wasnt " even close" to the 1/2 sleeve set either...lols
Old Jan 24, 2010 | 07:46 PM
Aquafina's Avatar
The shift linkage does not use a bolt to connect to the trans.
Old Jan 25, 2010 | 10:03 AM
092eg6's Avatar
i kno it uses a little pin, but what i was referring to was the joint part right behind the pin, it is 2 joint connected to eachother with nut and bolts.
jordan_rael_420
Oct 18, 2010 04:57 PM
KdF
Apr 14, 2010 06:52 AM
fast2camciv
Jul 29, 2007 02:16 PM
Mr Samson
Nov 2, 2003 09:30 AM
3rdGteg
Aug 30, 2002 05:40 PM
