TONS of honda parts leftover, 2000 civic si partout.
ALL STUFF IN PICTURES IS FOR SALE(except the boat and lawnmower)
ALL PRICES NEGOTIABLE, TRYING TO SELL EVERYTHING! a note to mention, this car was turbo and never seen weather, rain or snow. so anything you're thinking about buying know that NOTHING on this car is at all rusty. theyre about the cleanest 10 year old parts youre going to find.
PLEASE ONLY PM ME ON PARTS LISTED, MOTOR SWAP, FRONT END CONVERSION, DOORS, TRUNK, AND BUMPERS ARE ALREADY GONE!!!
all quotes are based off of being picked up, shipping will be extra unless you can jew me down!
$2000 si rad support, everything in pic comes with it. perfect for a 2000 front conversion or your wrecked car. make offer.
$COMPLETE 2000 CIVIC SI AIR BAG SYSTEM, SRS UNIT, HARNESS, AND BOTH BAGS. MAKE OFFER!
$ignition harness make offer
$complete center air control unit thing behind dash, everything but the blower motor. make offer.
$75-stock 2000 civic si spring/strut combo, i think they have like 23k. struts obviously good.
$2000 civic si cowl, mint, make offer.
$make offer-SI brake master cylinder
$make offer-winshield washer bottle n pump
$35 - Padawan power steering delete kit, used on my 2000 si for about 20k, love the kit.
$15- EBAY lowering springs, used for 100 miles on my buddies car 92-00 civic 94-01 teg
$make offer - both air bags from my 2000 civic si.
$75 - chipped vtec 5 speed obd1 ecu with spare reburnable chip(can do basemaps)
$-2000 civic si FUEL PUMP and the sending unit, both $80
$50-200 - 2000 civic si sunroof setup, perfect condition. you can even take the whole roof skin depending on what you need.
SOLD$175- COMPLETE si rear disc brake conversion off of the red car seen below. 86k miles, minty, only sitting since i wrecked it in july. coming with EVERYTHING including proportioning valve! other rear conv are going for this price without the 75 dollar prop valve. SOLD!
SOLD $100-5 speed conversion, pedals, lines, master and slave, everything but the linkage. SOLD
$25-rear glass for 2000 civic si/civic dx, ex, etc. mint, tinted one piece
mint oem honda winshield, in the car, make offer
$10-left and right side quarter glass.
$35, 2000 civic si headliner with visors pickup ONLY
$oem civic si suspension pieces, all good, make offer on what you need
$100-front 2000 civic si brake setup, calipers, brackets, lines, and rotors included.
SOLD-$50-milano red sideskirts SOLD
$15-b series clutch slave cyl
$150-2000 leather si steering wheel with airbag
$50-2000 civic si bare dash
$15-40ea-interior parts, ask about them.
$60-black 96-00 complete PASSENGER SIDE quarter panel, VERY good condition
si/gsr b series parts:
$45-ls throttle body mint, tested the sensors.
$5-oem gsr oil dipstick
$30-dsm 390cc injectors
$110-em1 civic si seats out of my car. mint FRONTS only
$40-t3/t04E turbo. only has 5k miles and is mint but the compressor sucked up a piece of plastic from the air filter and ruined the cold side fins. just needs the compressor fins. no play.
$80-b16a2 '00 civic si distributer
SOLD! $35-jdm gsr vtec solenoid setup-SOLD
$20-(2) oem spark plug covers b16 or gsr
$15-oem gsr/b16a water pump, low miles
$30ea.-(2) jdm gsr/b16a oil pumps, no ckf sensor since jdm, need chipped ecu both have low miles
-(3) bare jdm b16a blocks, $85-needs honing, comes with crank, $65-one needs boring, the last is good for core fee(cracked ringland)-$50
SOLD-$25-'00 civic si lower ac mount new in bag
$15-ARP rod bolts for d-series, 8mm ones, brand new, missing one bolt, fell out of package, 6 dollars from ARP. HUGE savings.
-(3) b16a2 timing belts, all under 15k miles, $5 ea.
$10-both trunk 50/50 tails, no qtr panel tails, just both trunk ones.
$30- both front oem 2000 si headlights, but both have busted mounting tabs
$20ea-(2)gsr/b16 factory oil catch can setups
SOLD!$20-gsr crank pulley with key and bolt.SOLD
$25-(2) oem tstat housings with water pipes
$50-b16 crank, mint
$40-b16 crank, one rod spun, still usable if repolished. did require largest bearing, now once polished will just step down a bearing color or two, ask for more info.
$10ea- jdm gsr oil filter water cooled housings(factory oil coolers)
$30-stock gsr fuel injectors, 240cc obd2 2 sets!
$40-GSR/B16 halfshaft
$40-stock b16 headers with downpipe
$30-stock gsr header
$40-stock 2000 civic si cruise control unit with acc's
$55-stock gsr butterfly secondary controller obd2
$15-stock 1.7 bar map sensor for obd2 bseries (have 4 of them)
$35-stock b16a2 fuel injectors obd1
$50-exedy stage one clutch kit for B-series, used, will need new clutch disk soon but the rest of it is great, was used in my 400whp si and couldnt handle the power. replacement disks are very cheap, its well worth 50 bucks for the pressure plate.
$15ea-(2) oil pressure sensors
$100-'98 civic ex power steering rack complete, same as '00 civic si.
a list of other stuff i need to sell:
$25-nextel i880 bad screen, its upside down
$30-nextel i710 mint
$40-nextel i850 MINT in box
$25ea-18x8" rims no tires only have 2
dsm parts:
$45-brand new RRM CAS harness to convert 7 bolt to 6 bolt. retails for $80
$50-KNOCKOFF evo 3 big 16g with o2 housing. ported and comes with ss oil feed and coolant fittings.BLOWN
$8ea-interior plastic pieces, grey in color, door, (3)hatch cover, rear pieces
$50-stock 4g63 cams
$20ea-dsm valve covers.
$25-95 awd turbo cruise control unit
$100-fwd turbo act steel streetlight flywheel, used for 200 miles
$10-2g wiper arms
$30-stock dsm side mount intercooler
lancer parts:
$50-evo 7 abs plastic wing
$40-evo 7 extreme side skirts(fiberglass)
shoot me a pm if interested in anything and remember parts are all OBO, i didnt really research prices im just trying to clean out my mess of a garage for the new project!
please bump if viewed!
thanks H-T!
ANYTHING ELSE YOU SEE IN THE MORE STRIPPED PIC IS ALSO FOR SALE. ANYTHING BIG IS PICKUP ONLY!!!
$50-b16 crank, mint
dsm parts:
$50-stock 4g63 cams
$10-2g wiper arms
lancer parts:
thanks H-T!
Last edited by maxum17ft; Jan 20, 2010 at 10:32 AM. Reason: added more parts to the list.
sorry for the shotty pics, it was cold out and my phone decided to suck at life.
if you see something u might want let me know and i can get better pics.
pete
pete
nopee. i only have the parts i have listed. i occasionally go to harrys u pull it but everything worth anything is gone in seconds up there.
