Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission problems
Old Jan 20, 2010 | 08:42 AM
leroy12's Avatar
Default Transmission problems
ok i drove my car all throughout the day yesterday and the car ran fine. i drove to my girlfriends house last night with no problems as well.
well i just went out side to leave and i started the car as normal and let it run for about 2-3 minutes while i talked on the phone.
After that i pressed in the clutch and proceeded to place it in reverse. The car then GRINDED like a bitch. so i was like WTF i tried again and the same thing happend.
i then tried to place the car in 1st gear but it the shifter wouldnt budge into place, and if i listen closely i can hear the ideal drop. its drops about 100-200 rpms when i try to place it into any gear other then reverse.
I checked my fluids etc..and everything is normal.
could it be my clutch is ****ed or is the transmission ****ed ?
thanks for any help!!!!
Old Jan 21, 2010 | 01:40 PM
Aquafina's Avatar
Default Re: Transmission problems
Check CMC and CSC for leaks, replace as needed. Bleed the clutch system. If those are good, pull the trans and inspect the clutch assembly. Replace if needed. If that is good, send the trans out to be rebuilt.
ChampwhiteH22-T
Sep 29, 2010 05:36 PM
93delslow315
Feb 5, 2010 07:08 AM
njdmej1
Jun 29, 2007 04:19 PM
Utilitarian
Jun 17, 2005 10:08 AM
92B20GSR
Mar 19, 2004 11:23 AM
