bspt or metric
Old Jan 20, 2010 | 07:31 AM
maxogsr's Avatar
Default bspt or metric
Car is 96 GSR
What is the adapter I need to "T" the EDC sensor... It's for an autometer water gauge... I'd like to keep the original sensor too...
1/8 bspt to 1/8 npt?
anyone knows?
Old Jan 20, 2010 | 07:52 AM
dpetro1's Avatar
Default Re: bspt or metric
pretty sure its 1/8bspt just like the oil pressure sensor. i think most people just use npt with some extra teflon tape. if you really want an adapter you can get one from mcmaster http://www.mcmaster.com/#4860k141/=5gicy2 i think it will be tough to find a tee piece with all the right sizes and also there is limited space to tighten a bulky tee fitting.
alternatively you could get a radiator hose adapter off ebay for pretty cheap
Old Jan 20, 2010 | 09:06 AM
maxogsr's Avatar
what i don't like about hose adapter is that it dosen't read head temp... It's on the other side of the thermostat...So if the thermostat jam...
Old Jan 20, 2010 | 09:10 AM
dpetro1's Avatar
not if you put it on the top hose. the top hose heats up with the head
Old Jan 20, 2010 | 02:14 PM
maxogsr's Avatar
your right... I'd be curious to see that set up... anybody have a picture?
But I would still want to know the answer about my first question... I might try that route first
Old Jan 20, 2010 | 04:34 PM
maxogsr's Avatar
So anyone knows for sure what is the thread pattern and size (bspt or npt or metric)?
Old Jan 21, 2010 | 05:53 AM
dpetro1's Avatar
1/8bspt but again its gonna be tough to find all the right adapters and everything. i searched mcmaster for at least an hour looking for some kind of bspt -> npt tee with no luck. also you would need to be careful of the added weight of adapters and tees, it could crack the head similar to when people tee for turbo oil lines in the block
Old Jan 24, 2010 | 12:22 PM
maxogsr's Avatar
Autometer part 2269... It's something like 12$ http://www.autometer.com/cat_accesso...il.aspx?vid=59.
I'm alwready "t" behind the block at the pressure switch for oil pressure... I have put a 6 inch highpressure rubber hose before the "t". Have 40 days of track with that set up last summer and never had any issue...
Old Jan 24, 2010 | 12:58 PM
95 integra's Avatar
EDC sensor? I could've sworn that was a dampner sensor on a shock that Integras done have.
Old Jan 24, 2010 | 02:42 PM
dpetro1's Avatar
good idea. i always try to remote mount sensors like that as well.
Old Jan 24, 2010 | 03:03 PM
maxogsr's Avatar
Loll! that's funny... I meant ECT.... EDC isin't the Tein thing that aloud you to adjust the damping/rebound of the shock from inside the car?
Thanks for notice it!
VTEC_Honda
Sep 16, 2011 08:03 AM
95DC2GS-R
Jul 1, 2010 08:05 PM
Unseen Racer
Aug 2, 2008 10:04 PM
neocrynym
Jul 2, 2006 05:40 PM
asiansgoweeee
Nov 3, 2004 08:03 AM
