Suspension & Brakes Theory, alignment, spring rates....
question about extended studs on 4x114.3
Old Jan 20, 2010 | 04:18 AM
crxfornow's Avatar
Default question about extended studs on 4x114.3
i was just wondering if you have to remove the front hubs on the jdm itr 4x114.3 front knuckles to install arp extended studs.
i know you have to for the 4x100 because they wont clear the area around the wheel bearing,
but im wondering since the front hubs are larger in diameter, and they use the same front wheel bearings as the us integra 4x100 counterparts if the studs will clear the wheel bearing area?
any help will help out alot thanks in advance
Old Jan 20, 2010 | 05:56 AM
phunhaus's Avatar
Default Re: question about extended studs on 4x114.3
Yes to removing the hubs.
Yes to the same bearings as 4x100 DC2.
Whatchya got up your sleeve?
Old Jan 20, 2010 | 03:50 PM
crxfornow's Avatar
really brandon is there anything you dont know
Old Jan 27, 2010 | 11:27 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Another option is to grind the knuckle to create a "path" for the stud. You can then slip in the stud without having to remove the hub.
This is what I did for my 4x114 ARP studs and I dont see any drawback to it.
It may seem a bit half-***, but I like the ability to swap out an individual stud if ever I should break one. And I've broken many.
ef90b16
Nov 28, 2008 09:36 PM
erikiksaz1
Apr 9, 2007 08:32 AM
teamvirus
Jun 14, 2006 01:36 PM
9seccivicsi
Feb 11, 2004 06:07 AM
EK MONEY
Nov 2, 2002 05:47 PM
