Transmission & Drivetrain Gearboxes, Differentials, Clutches
Re-greasing the intermediate shaft?
Old Jan 19, 2010 | 07:31 PM
SolAssassin's Avatar
Default Re-greasing the intermediate shaft?
I have an old DA Integra intermediate shaft. I am replacing the outer seal on it, but it doesn't spin very well. I'm thinking of using some wheel bearing grease on it, but how much should I use? Should I be conservative with the amount I use or just slap a big amount in there?
Old Jan 20, 2010 | 04:29 AM
unusual71's Avatar
Default Re: Re-greasing the intermediate shaft?
if you put too much the extra will just come out and make a mess thats all. However if a bearing is hard to turn sometimes its worse than just being dry.
Old Jan 20, 2010 | 05:08 AM
It's not "hard" to turn, its just that it doesn't spin as freely as some other ones I've had. I'm thinking a little grease will do the trick, I'm just not sure if there is anywhere in particular to lube inside the shaft.
Old Jan 24, 2010 | 07:39 AM
I figured out my own problems... I removed the outer seal, cleaned out the gunk, sprayed some Aero-Kroil and let it seep and then used Lucas 540 drop point bearing grease with a brand new outer seal and she spins like a dream
theYBLEGAL
Aug 20, 2013 11:50 AM
garyc17
Feb 4, 2009 04:53 AM
B16CRXT
Aug 27, 2008 06:25 AM
blackoutcivic
Jul 17, 2005 12:55 PM
cknisley
Jul 3, 2005 06:13 PM
