question about jdm cams???
did a search but still couldnt find the answer
i know that 2000-2001 itr usdm cams are almost the same as CTR cams. but what about the 96-up JDM cams? are they similar to the 00-01 usdm ones or less agressive? i just need some info, thanks guys.
[Modified by clemens, 8:22 PM 9/5/2002]
ctr intake cam is slightly diff. then the itr intake cam.
exhaust cams pretty much the same.
someone correct me if im wrong.....
96-up jdm spec??
[Modified by Yes it's VTEC, 4:45 AM 9/5/2002]
but what about the 96-up cams?
yeah, exhaust cams for itr/ctr are the same based on the information i know, and the intake is 243@1mm for CTR and 240@1mm for ITR (00-01 usdm)
what i'd like to know is if its the same for JDM cams from the year 96-up. i have a pair of 97 spec R (jdm) cams and would like to know if the specs are the same for 2000-2001 usdm cams
^R@m!r0_(M)
Jan 28, 2004 05:16 AM
