91 integra - speedo doesnt work
Old Jan 18, 2010 | 04:42 PM
Urthwrite's Avatar
Icon6 91 integra - speedo doesnt work
so I have taken the gauge cluster out numerous times before, I took it out to put in a new light and after it was back together after only about a block of driving the speedo stopped working. I can drive for about 5 min until the check engine light comes on but when I turn the engine off, the light turns off too, so I am having problems with the ecu led trouble codes. I thought the cable might be bad? I removed the gauge cluster and took it around the block to see if the pin in the cable spun, it doesn't. I thought it might be disconnected from the tranny but after checking, its still hooked up with the pin and doesn't pull out without removing the pin first. Is there something else I can check before having to replace the cable? could it be something other than the cable? I heard about a speed control sensor but can't find anything about it, is that a different gen integra? any help is appreciated.
Old Jan 18, 2010 | 07:09 PM
zedron's Avatar
Default Re: 91 integra - speedo doesnt work
The VSS (Vehicle Speed Sensor) could be bad. If standing on passenger side of car looking at distributor, go below dizzy and to the left. It is located on the transmission below the thermostat housing to the left.
Old Jan 18, 2010 | 11:35 PM
cybreedjay's Avatar
the DA chassis didnt come with a vss they were cable driven.
Old Jan 19, 2010 | 12:01 AM
zedron's Avatar
Uhh yes it does. Its just not electronic.
OP: Here is a link to some info that might help you out in troubleshooting it.
http://techauto.awardspace.com/vss.html
Old Jan 19, 2010 | 06:52 AM
ls-civic_18's Avatar
New User
im having the same prob i have a cable tranny that has been converted to hydro
Old Jan 19, 2010 | 12:45 PM
Urthwrite's Avatar
so is the vss located by the place that the speedo cable goes into the tranny?
Old Jan 23, 2010 | 02:14 PM
nAkiZzO_91's Avatar
i have the same problem too. i was told it was a sensor or something. gotta check it out.
Old Jan 23, 2010 | 05:47 PM
4doortegragirl's Avatar
New User
My tack and all other gauges were working, except the speedometer. Switched out the speedo sensor and works just fine
Old Jan 23, 2010 | 06:24 PM
nAkiZzO_91's Avatar
did you also own a 91? if so then im gonna do what you did and see if it works.
Old Jan 23, 2010 | 09:04 PM
1994RedIntegra's Avatar
You can definitely get a speed sensor from the junk yard..That will be your best bet.
Old Jan 23, 2010 | 10:36 PM
jdmef9gsr's Avatar
pull the cable out completely and make sure the original grease isnt all gunked up in the housing which will prevent it from spinning correctly.
TegraGSXR
Apr 15, 2010 10:24 AM
EF9 JAMS!!!
Mar 26, 2006 01:27 PM
Backk InTheDA
Apr 22, 2005 04:20 PM
scorched0
Feb 1, 2004 07:23 PM
manson
13
Jul 17, 2003 06:44 PM
