wrapping my header
Old Sep 4, 2002 | 06:17 PM
zcivic91's Avatar
Default wrapping my header
i just got some wrapp for my comptech 421..its ss.
it looks like ill have to take it out to do it properly being its a 1 peice..
is this going to crack my header..and if so can i reweld it if it does?
it just gets too hot in there..i need to cool it down somehow..
also im going to wrap the aem cai,a/c lines and cooling hoses....is this safe..?
Old Sep 4, 2002 | 06:31 PM
ijjz's Avatar
Default Re: wrapping my header (zcivic91)
I heard wrapping it will kill the life of your headers, they might only last a year. The reason racers do it is because they will be replacing it soon anyways. But it does supposivly helps, but if you dont want to keep on buying new headers I would advise you not to wrap them.
Old Sep 4, 2002 | 06:39 PM
zcivic91's Avatar
Default Re: wrapping my header (ijjz)
who knows where ill be in a year..probly not wit the civic
Old Sep 4, 2002 | 06:40 PM
ijjz's Avatar
Well it could only be a a few months, I do not know. I just have heard it will cut the life of your headers dramatically.
Old Sep 4, 2002 | 06:49 PM
b18bvtec4drteg's Avatar
"i just got a 1" by 50 foot on the way..the thing is that i have a 1 peice header and it would be difficult to remove it..so can i manage just leaving it in and wrapping it? also if i cut it up into 4 peaces it would be easier right?
how much does it reduce underhood temps?? can u touch the header when its hot...since u got the wrap on it?"
https://honda-tech.com/zerothread?id=266415
I see that you saw my post. Yes I ordered the same exact length wrap u got. I only got to wrap a good half of it. Yes it would be easier to cut it in 4 different pieces. But its messier imo. That means u will need 8 hose clamps. Trust me you will want to take the header out to do the wrap. Yeah I touched the header and no burn! The temp is unbelievably low now.
With the CAI and A/C lines you need reflective tape. But since I had some leftover, I just wrapped my A/C line and no problems.
Old Sep 4, 2002 | 08:34 PM
USDM 4G VTEC's Avatar
Default Re: wrapping my header (b18bvtec4drteg)
"ihow much does it reduce underhood temps?? can u touch the header when its hot...since u got the wrap on it?"
LMFAO
yeah i wanna see u touching the headers when they are hot with the wrap lol that **** its funny......
its reduces engine bay temps by like 40 deg...... no exagerated changes...... and yes they are still hot.. u can spit on them and before the spit touches the header they will evaporate....... ill say around 300deg....
Old Sep 5, 2002 | 06:23 AM
EF8_SiR's Avatar
How do wraps lower the life of ur headers?
Old Sep 5, 2002 | 06:26 AM
Default Re: wrapping my header (EF8_SiR)
well the headers by itself let the heat go out of them to the engine bay air (cooling off) ..... when u wrap them , they reduce engine bay heat wich means the heat gets concentrated into the headers only... headers will be too hot since they are wraped... too much heat, for too long will reduce the life of the metal compund, meaning on cracks, or metal getting fragile and brittle.......
Old Sep 5, 2002 | 06:50 AM
zcivic91's Avatar
Default Re: wrapping my header (JDM EF9)
i got the 2" by 50" since my header is a 1 peice 421..i must remove it to do it correctly. i cut 2 peices of the appropriate length(13ft) so i can wrap the header in 2 sections..its easier this way and less clamps.
i also have some reflective tape in the garage that we used to tape on a drier duct elbow for the drier...hmmm its heat reflective and pretty..
dam before u know it ill be sucking air the eingine bay as a/c it will be so cool in there..
Old Sep 5, 2002 | 11:37 AM
Urban Business
Guest
Posts: n/a
header wrap will eventually crack your headers. its basicly ment to insulate your engine bay. its also *suposed* to force heat downward twards your exhaust. because of increased header temp they'll **** up eventually
Old Sep 5, 2002 | 02:53 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: wrapping my header (TorteX)
when you buy a header, most of them come with a warning advising you NOT to use header wrap as it will ruin the header.
don't do it man. it won't make that much of difference, and it's not worth your header.
Old Sep 5, 2002 | 03:25 PM
WickedZ's Avatar
Default Re: wrapping my header (two.oh)
i have it on my car and it does make a big difference... ur car runs a lot cooler and yes u can still touch the hedders while the engine is running (notice i said touch not grab it and hold it)...
Old Sep 5, 2002 | 04:15 PM
NikoZai's Avatar
stainless steel headers wont crack from being wrapped but ceramics always will.
I wouldnt wrap the header unless its a true race car.
Old Sep 8, 2002 | 12:05 PM
zcivic91's Avatar
Default Re: wrapping my header (NikoZai)
ok so i wrapped it today...the enige bay it a bit cooler..
but the dam wraps are smoking alil? also the still get pretty dam hot..wats wrong!
Old Sep 8, 2002 | 03:58 PM
slowman's Avatar
I took way too long
just wrap the A/C lines and get a low temp stat.
Old Sep 8, 2002 | 06:33 PM
zcivic91's Avatar
Default Re: wrapping my header (slowman EF)
i had enough left over for my intake and a/c lines..
but my header wrap is turning dark..its it supposed to do this..
Old Sep 8, 2002 | 07:06 PM
Steve Berman's Avatar
sup·posed·ly (-pzd-l) adv.
Synonyms: supposed, conjectural, hypothetical, putative, reputed, suppositious, supposititious
You can get a cheap ole chikara header for about a hundred or so, so who cares about it rotting out. I would do it. I mean, why not cool down that engine bay>? If we really cared about what would happen to our engines a year into the future, I don't think we would be modifying them to begin with.
i love racing
Old Sep 9, 2002 | 06:56 AM
zcivic91's Avatar
Default Re: wrapping my header (Steve Berman)
wat the heck does header wrap have to do with the motor??
all i can see is it running cooler..
Old Sep 9, 2002 | 08:28 AM
1QWKCRX's Avatar
Not only does wrapping the header trap heat to the header, it also traps moisture
that just speeds up the rust/corrosion process.
As mentioned before, unless you have the funds to buy a new header every year, it's not recommended. There are plenty of other ways to battle engine heat.
WaterWetter can be added to your coolant to help reduce motor temps, plus there are various insulations that can be used on other items (brake fluid, distributor, etc) to keep them from getting heated up by the motor.
Old Sep 9, 2002 | 08:39 AM
zcivic91's Avatar
Default Re: wrapping my header (1QWKCRX)
i dont think ill be using my car in a year if not still owning it..since im goin to the airforce in 2 months..
Old Sep 9, 2002 | 09:00 AM
ijjz's Avatar
When I go to buy a car, and I see the headers are wrapped, or can tell. I tell the guy to subtract how much those headers cost from the final price because that is something that I will be needing to replace very soon. My friends do it as well. Wrapped headers for just street use is pointless.
Old Sep 9, 2002 | 09:03 AM
Urban Business
Guest
Posts: n/a
stainless cracks easier than ceramic
em1guy909
13
Oct 9, 2010 12:31 PM
adam4lsu
Apr 25, 2007 04:15 PM
Demonis
Honda Civic (2006 - 2015)
Oct 7, 2006 09:49 PM
FlatlineEF9
Aug 27, 2003 06:03 PM
Turbo Powa
13
Jun 1, 2002 04:22 PM
