anywone tried this pistons
Old Jan 18, 2010 | 01:45 PM
eyji-'s Avatar
Default anywone tried this pistons
I am thanking about baying this pistons bun I need to know if this is some junk or good pistons.. have anybody tried this here
http://cgi.ebay.com/ebaymotors/B20-8...Q5fAccessories
Old Jan 18, 2010 | 01:51 PM
Red_Army's Avatar
Default Re: anywone tried this pistons
couldn't even tell you since they don't say. but usually ebay is not the place for engine parts.
Old Jan 18, 2010 | 06:45 PM
forsakenriceboy86's Avatar
i agree with "red army".. i've seen some pretty badd results with ebay product when rebuilding engines, but its really your call... research that piston a bit more before deciding, i've never heard of that brand before tho.. gOod luck with which ever decision you make.! :D
Old Jan 18, 2010 | 07:11 PM
BigDare23's Avatar
I used the 84.5mm version of those pistons in my b20vtec
results (with bolt-ons and CTR cams)
Old Jan 19, 2010 | 03:53 AM
eyji-'s Avatar
okei but is the block guard nessesery? for high compression
Old Jan 19, 2010 | 04:10 AM
GhostAccord's Avatar
Only a suggestion but I wouldn't go cheap when it comes to engine internals. No need for a block guard, they cost more to have properly installed then they are worth.
Old Jan 19, 2010 | 04:57 AM
hey man's Avatar
honestly it all depends on the CR ur aiming for ...
Old Jan 19, 2010 | 08:33 AM
BigDare23's Avatar
It's not. I only did it because I'm using stock sleeves and I overbored them. I decided to add it for more "protection". I also added an aftermarket girdle and GSR arp main studs which the average person wouldn't have done. So I kind of went over boarded on a basic build. If you do decide to use a block guard, get it pressed in at a machine shop. Then get the cylinders check for straightness, and last get your machine work done. Most people on the forum say block guards are the devil, but I didn't care because I got mines installed properly.
(and please don't make this a debate about block guards LOL)
As for the pistons, even though those are "ebay" pistons, they are Nippon brands, and they make pretty good stuff.
Old Jan 19, 2010 | 10:09 AM
eyji-'s Avatar
okei thanks for that I think I'm not going to use block gourd btw in what theard shuld I put put my project in ? I'm a noob on honda-tech:'D
89ED
Dec 31, 2013 09:23 AM
junior_tm
Oct 11, 2008 07:18 AM
all-mtr-teg
Apr 20, 2008 06:04 PM
b20vtech
Mar 21, 2006 07:26 AM
