Some turbo parts FS
Old Jan 18, 2010 | 07:53 AM
reysi1026's Avatar
Default Some turbo parts FS
OPen to trades
BOV $45 obo as is shipped
Blitz electirc boost controller $165 obo as is shipped
The SBC i-D (Sequential Boost Controller i-D) is the latest boost controller offer by BLITZ.
This unique boost controller represents the cutting edge in boost controller technology. The SBC i-D features the same dual solenoid design as the DSBC for maximum boost response and the capability to hold up to 36.75psi (2.5 bar). The SBC i-D is 1/2 din size and it is compatible with internal actuators and external wastegates.
**Boost Unit - Boost can be displayed in standard and metric measurements (PSI, bar, kPa, and kg/cm2)
Four Channels - Has 4 different programmable boost settings.
Boost Gauge - The SBC i-D can display boost in digital and graphical form.
Peak Hold - SBC i-D can record the highest boost achieved by the vehicle.
Boost Warning and Limiter - This is a safety function that allows the operator to set the amount of boost decrease in the event of over boost. Warning is in both visual and audible.
Manual or Automatic boost setting - The SBC i-D allows the user the choose how the boost is set.
Manual - Sets boost in ratio, from 0-100. By using the manual setting, this allows the boost controller to give maximum boost response.
Automatic - Sets boost directly, just dial in desired boost amount.
Record and Replay- SBC i-D has the ability to record and replay any information up to 99 seconds. The SBC i-D can also record and replay information on the Power Meter i-D and Optional Data (Power Meter i-D and SBC Optional Harness required). Replay can be fast forwarded and replayed in 2x and 5x.
Display - The SBC i-D can display up to 6 different vehicle reading. Each reading can be display in both digital and graph form. SBC i-D has the option to display 5 other vehicle reading (Power Meter i-D and SBC Optional Harness required). With Power Meter i-D, the SBC i-D can display SPEED and POWER. With SBC Optional Harness, the SBC i-D can display 3 different electronic outputs from the ECU.
Boost - Digital and Graph Form OPT1/SPEED - (Power Meter i-D required to display speed) V Digital and Graphic form. OPT2/POWER - (Power Meter i-D required to display power) - Digital and Graphic form. DATA 1 - (SBC Optional Harness required) - Digital and Graphic form. DATA 2 - (SBC Optional Harness required) - Digital and Graphic form. DATA 3 - (SBC Optional Harness required) - Digital and Graphic form. DATA 1-3 Display- This boost controller has the ability to display any electronic output from the vehicle ECU (SBC Optional Harness required). It can display almost any voltage output from the computer (i.e.: TPS, temperature, pressure, A/F, injector pulse and etc.). DATA 1-3 readings can also be recorded and replayed.
Speed Map - This unique feature allows the SBC i-D to control boost according to the speed of the vehicle (Power Meter i-D required). Speed Map boost control can be set up from a 2 stage to a 4 stage control, which allows the user to set boost according to his driving style. Speed in transfer by infrared between the Power Meter i-D and SBC.
Old Jan 18, 2010 | 10:29 AM
reysi1026's Avatar
Default Re: Some turbo parts FS
Old Jan 18, 2010 | 09:01 PM
reysi1026's Avatar
Old Jan 22, 2010 | 01:34 PM
reysi1026's Avatar
no bad offers refused....
reysi1026
Jan 22, 2010 01:34 PM
Integra21
May 21, 2006 04:16 PM
Integra21
May 21, 2006 04:15 PM
Tony Starks
Sep 23, 2003 06:53 PM
