ELMINATE the idler air valve on skunk 2 intake mani with 80mm throttle body?
Old Jan 17, 2010 | 09:23 PM
80 dolla crx hf's Avatar
Default ELMINATE the idler air valve on skunk 2 intake mani with 80mm throttle body?
Once you bore the intake mani out past 74mm on the skunk 2 intake mani it puntures through the idler air valve.
I need to eliminate it since i am running a 80mm tb.
Any help? Can i unplug it, leave it on there just block it off, or rechip the ecu and have the ecu ignore it?
Old Jan 18, 2010 | 08:28 PM
Default Re: ELMINATE the idler air valve on skunk 2 intake mani with 80mm throttle body?
Any takers?
Old Jan 19, 2010 | 06:05 PM
turbodcxbro's Avatar
Most all chipping systems will allow you to ignore it, I know CROME does and I think Hondata will also. Then just make a block off plate for it and be done with it!
Old Jan 19, 2010 | 06:46 PM
i am using crome would i have to have a tuner reprogram it?
Old Jan 20, 2010 | 01:56 PM
Or you can, crome is free and all you need is a moates Burner.
fuzzysig
Dec 2, 2016 01:11 PM
g2tegsown
Aug 21, 2006 01:15 PM
mkiv98
Jan 30, 2005 03:37 PM
whatVTEC
Sep 19, 2003 10:42 PM
HX_Guy
Oct 17, 2001 09:46 AM
