Engine Rebuild
We started my engine rebuild today. What a pain. Pictures!
Where it started
Air cleaner off. Vacume line hell.
A random pile of Shi* I collected just to get the head off.
Intake and Head
Closer view of the head. You can see the little cvcc springs and valves.
Combustion chambers. Where's the spark plugs?! (cvcc
The block and how it sits as of now.
There will be more updates as I work on it.
Where it started
Intake and Head
If you really want to get rid of that spagetti, I would try and find an older carb and manifold.
Here is a pic of my 75 CVCC set-up, Yes this is a stock 1.5l
And I just got rid of a manifold too.
I am glad to see your rebuild. I have my original motor that I am going to rebuild soon.
If you put that motor, and the EK1 side by side, I don't know if you'd be able to tell them apart! Even the carbs look the same... Progress is looking good! Keep em up!
You can still do the Weber conversion. I've been running one on mine forever, and the intake manifold is damn near identical. The adapter plate has provisions for the CVCC aux runners and chambers.
And unless 83 is drastically different from 82, it's the same adapter plate as the EK1...
http://www.piercemanifolds.com/Catalogpages/honda.htm
Here's my intake manifold with adapter fitted and port-matched
^^^ looks just like my 83..
what are you going to do about head bolts? are you going to try to reuse the old ones or get new? the cheapest I could find them for my ek1 was about $18. each
I hope you have better luck than me
They're supposed to be reusable, but it seems to me like they are stretching for a lot of people, ala blown head gaskets. Where did you get yours head bolts from? Were they OEM Honda? I am amazed you can even get them...
Hmm, that's interesting. I wonder if I could order D15 head studs from ARP and cut them down to fit the EK1. Will have to investigate further. Thanks for the tip. Sorry about the thread jack, but might be relevant during the rebuild? :D
Its ok. The more I know the better.
As far as updates go, they're are none. I was very busy last couple of weekends so hopefully this weekend there will be some progress
The ES motors are going to be a little more tricky to mount in there. The mount layouts are similar, but the problem is you can't bolt your Civic transmission to that block. However, with the EK, from what I remember reading, you can bolt your stock transmission to it. Only tricky part I recall is the dogbone mount. The 1stgenCivic forums should have all the detailed info on that particular swap.
Amazing you still have the original clutch! Pretty crazy! Also, can't believe you left the transmission in the car! That's a lot of work! Must have made it tough to pull out. It's waaay easier to pull the axles and bring out the engine and trans as a unit. To get the axles out, you just gotta pop the spindle nuts, and drop the LCAs then pop out the axles. But hey if this worked for you, sweet! :D
This should be a nice project to see through to the end.
