aebs intake mani vs stock itr mani???
which one is better for my set up: aebs or stock itr??
stock jdm gsr block
stock valvetrain b16 head w/ itr cams
can i get some info, dyno sheets, etc etc
thanks ht
stock jdm gsr block
thanks ht
sounds like itr then huh?
The only problem back here in Portugal, is that an used ITR IM is abou 100 € more than a brand new AEBS...i´m planning on building an LS VTEC, using a Stock B20 Block and B16A2 ported Head, with 3 angle valve job and later on ITR Camshafts...since the AEBS IM comes with a larger bore, I think using the 65mm will be good enough for the setup! What you guys think?
rodimus
Dec 27, 2004 02:36 PM
