LS vs GSR exhaust systems. Noob question
Old Jan 17, 2010 | 10:37 AM
swiftstyles's Avatar
Default LS vs GSR exhaust systems. Noob question
I have a 94 LS/GS with a jdm GSR swap. I see that there is a difference in exhaust systems when trying to order one. Do I stay with the LS/GS system? Whats the difference with the LS/GS vs the GSR system?
Old Jan 17, 2010 | 12:29 PM
TheAsian's Avatar
Default Re: LS vs GSR exhaust systems. Noob question
All you need to do is get a exhaust to match your car. If you have a 2 door get a 2 door exhaust and vise versa. Then get a adjustable test pipe problem solved. Be sure once you get the test pipe fitted to weld it up or else it can slide apart on you.
mannydhanju
Feb 22, 2009 12:42 AM
Honda_Fanatic
Mar 6, 2007 09:10 PM
Fresno_NSX
Feb 23, 2005 01:35 PM
