fs: Holset HE351cw
Old Jan 17, 2010 | 09:28 AM
sparknock's Avatar
Default fs: Holset HE351cw
i have a holset HE351cw.
if you do the math to figure out the trim
((58.6 * 58.6) / (84.6 * 84.6)) * 100 = 47.9793661
compressor
inducer : 58.6
exducer : 84.6
turbine
exducer 57.7
inducer 64.8
the exhaust housing is a 9cm^2 and is a T3
in terms this would be great for a high hp 1.8 and up 4 cylinder or a mid hp 6 cylinder
the compressor inlet is 4" OD and the outlet is 2.75" OD the outlet ID is 58mm
in terms of a pure garret, that's comparable to gt3582r for both compressor and exhaust which is rated at 400 - 600 crank hp and the compressor alone is comparable to the gt3776 gt3782 gt4082 which are rated to ,550hp, 575hp respectively, but the holset has a smaller exhaust wheel than those.
this turbo came from a truck with 29k miles and there is not one ounce of shaft play.
insurance will be required on the shipping
thing can make 42+ LBS/boost and ask for more
as it runs 33 lbs on the ISB Cummins engine
looking to get 300+shipping out of it.
click on the picture to get a full size image
Old Feb 7, 2010 | 10:40 PM
ME=ADRIAN's Avatar
Default Re: fs: Holset HE351cw
pm
Old Nov 2, 2010 | 05:59 PM
twisselman1968's Avatar
any chance you still have this turbo
hardcore97
Feb 27, 2013 08:32 AM
J98BlueGSR
Aug 4, 2009 07:19 AM
zex_cool
Apr 26, 2008 08:00 AM
RacerStev
Oct 21, 2003 05:58 PM
DRAGLS
Feb 9, 2003 07:43 AM
