Non-Typical H22A Swap Help
Old Jan 16, 2010 | 09:06 PM
SMSGuy's Avatar
Default Non-Typical H22A Swap Help
I am building a tube chassis very similar to a Polaris RZR and have been searching for an ideal engine to put in it and I am leaning heavily towards a H22a Euro-R that is on Ebay. I have been looking into a custom harness and have a few questions.
I have been told that I will need to run a Internal Coil Distributor, that the IAB and EGR circuit will not be wired and that I will need to run a Chipped ECU.
I want to keep this engine as simple as possible no fancy extra control boxes or high end tuning just a reliable engine. I also need to make it water proof cause its probably going to see some deep water so I also want it stripped down to its bare essentails to make it a clean install without a million hoses and tubes that can leak.
What ECU should I run?
Who can tune it to run with the items above removed?
What extra items can be removed to clean it up a bit?
Thanks for you help!
Old Jan 26, 2010 | 03:28 PM
SMSGuy's Avatar
Default Re: Non-Typical H22A Swap Help
I know this really doesn't fall into the normal use for these engines, I have always been a fan of the Small block chevy and have taken them to all extremes. I have just begun exploring the possibilities of the 4 cyl and I am amazed at what can be done with these engines. Lend a fellow gearhead a hand here because I have read a million posts on how to make my mom's car go faster and I can't get the answers I need to move on with my project.
Old Jan 26, 2010 | 04:59 PM
Turbogixxer's Avatar
Euro Rs do not have IABs, but have EGRs. If you get a chipped civic/integra ECU, it does not look for a EGR so you do not need it.
Any chipped p28, P72, P30 or converted vtec ecu.
Who as in a tuner? or as in a system?
you can remove 02 sensor, purge control, Vtec pressure swtich (if the euroR has it).
Old Jan 26, 2010 | 07:22 PM
SMSGuy's Avatar
I contacted Rywire about making a custom harness for it, they gave me the information I listed above. So basically I need the harness, P28 ECU, a chip for it and somebody to tune it.
The Euro-r has no IAB's so that is simple, Plug the EGR, Remove Purge valve because i will be running a fuel cell and I assume the Vtec psi switch is just s low oil psi switch to keep the Vtec from engaging so that can go.
I would assume the O2 would be good to keep cause it will allow the engine to correct the A/F ratio.
Once this is gathered up I am still going to need someone to write a tune file for it, or will the P28 have the tune on it and the chip will just bypass the ECU looking for the removed items?
This seems simple enough, I don't want to spend weeks trying to tune the engine as I have in the past with my big motors... Thanks for the response so far.
Old Jan 27, 2010 | 04:31 AM
Stock 02 is only good for 14.7. It is narrowband. So it is not really needed.
Yes, if you chip it, you can remove those. You just need a software to do it. Neptune Demon works great and is easy to set up a base map. more info here: http://www.hrtuning.com/pages/category/neptune-rtp
Old Jan 27, 2010 | 03:35 PM
SMSGuy's Avatar
Thanks for you help, I think that gives me all the info I need to know that I can get the engine running and that is a load off my mind.
Does anybody else make custom harnesses for this engine?
Old Jan 27, 2010 | 07:54 PM
Rywire can. They are pretty simple to make if you have the right info.
pchee373
Apr 12, 2006 01:08 PM
Dred
Apr 10, 2006 02:58 PM
mightymikek83
Jun 15, 2005 01:59 PM
bchambers05
Jan 26, 2005 09:46 PM
prelude311
May 23, 2002 09:50 PM
