2005 civic door locks broken
Its my girlfriends car, the drivers side doors wont respond to the switch but when you pull the interior handle or lift the outside handle and push the indicator **** on the door sill it will lock all the doors. when you hit the keyless entry remote the car will acknowledge it but it wont unlock any of the doors.
Is this a bad actuator? Or is there possibly a bad fuse?
also, the rear drivers side door wont respond to the lock switch; if you lock the doors using the switch on the drivers door it will only lock and unlock the passenger side doors. The rear drivers side door can only be locked and unlocked manually. Are the actuators bad on both the drivers side front and rear doors?
on my 2001 civic when i had it, i could just pull the handle on the inside and hit the lock switch to lock all the doors when i was trying to lock all the doors. That doesnt work on this sedan. Any input is appreciated!
Okay i had a similar problem although mine is a 2002. The best bet would be to check the fuse panels for any fuse or relay that controls that section if that is not the situation then the actuators should then be checked by a electrician or your trusted mechanic.
MIBPreacher
Honda Civic (2001 - 2005)
Feb 3, 2013 04:38 PM
