do i need a tune
Old Jan 16, 2010 | 11:24 AM
worx's Avatar
Default do i need a tune
was good H-T? I have some blox stage2 cams and crower springs and retainers some arp studs. I want to know if I can install these parts and still drive around with out being tuned? thanks in advance.
Old Jan 16, 2010 | 11:26 AM
zedron's Avatar
Default Re: do i need a tune
Sure, but you will not reap the full power potential from your new cams.
Old Jan 16, 2010 | 11:45 AM
green_eg_hatch's Avatar
yea id drive it un tunned to the tunner only.
Old Jan 16, 2010 | 12:12 PM
Arthas's Avatar
Bakersfield lulzzz..
Yeah drive it untuned bro dont even worry about it. Honda added a seperate fuel map for people who are going to add Blox stage 2 cams later on down the road. Also, make sure you red line every gear.
Old Jan 16, 2010 | 12:27 PM
worx's Avatar
and spray nitrous too huh arthas? dik, i was asking if i could or not. honda did add a separate fuel map which is in limp mode. Ive heard people run stage 2 cams untuned without a issue but only heard.
Old Jan 16, 2010 | 12:31 PM
Arthas's Avatar
Why are Honda people so cheapp?? Everyone wants to create more power without getting a tune... I wouldnt even think about installing cams without having my tuner available for an appointment.
Dont come to me when youre fuel map has a nasty hole because thats why youre unloading in third.
Old Jan 16, 2010 | 01:08 PM
all-mtr-teg's Avatar
Make a list of all the bad things that can happen if you drive a car with stage 2 cams, on a stock ecu. Then decide if that list of bad things outweights coughing up $300-400 for a chipped ecu and tune.
Old Jan 16, 2010 | 01:51 PM
worx's Avatar
well i have i chipped ecu not for this set up though. the nearest tune shop is about a 2hr drive. I can wait till im ready to take it to get tuned to install the other head im in no rush, i just thought I'd ask since i had nothing to do today.
Old Jan 16, 2010 | 02:42 PM
Arthas's Avatar
Why would you have a chipped ECU from a different set up on your car? Thats just asking for problems.
Old Jan 16, 2010 | 02:49 PM
racebum's Avatar
Q: can i change cams and not tune?
A: NO! there is no single part of the engine that effects vacuum more
Q: can i change the intake and not tune?
A: yes but fuel pressure will need to be adjusted on a wideband to get the AF right, even then you should have a tune done to address timing changes in the map
Q: can i change compression without a tune
A: most the time no but small changes like half a point can be done
Q: can i change my exhaust without a tune
A: yes but even with this there is often a couple hp in tuning
Old Jan 16, 2010 | 07:56 PM
omnirage's Avatar
Props for not being a smart ***.
I'm not sober, that is all I have to say about that.
Old Jan 16, 2010 | 08:30 PM
1320RHD's Avatar
TUNING IS THE WAY TO GO
Old Jan 17, 2010 | 01:06 PM
keepinitrehaal's Avatar
Clap clap clap!
Old Jan 18, 2010 | 11:34 PM
worx's Avatar
dam need to find a trailer
Digital_Freedom
K Series
Dec 17, 2015 07:41 AM
smithb299
Dec 2, 2008 07:52 AM
FA5civicSI
Honda Civic (2006 - 2015)
Oct 18, 2008 06:19 PM
fastludeh22
Aug 2, 2002 06:25 AM
fastludeh22
Aug 1, 2002 10:35 AM
