LOOK AT MY TIMING BELT AFTER 72MILES ON REBUILD
Old Jan 15, 2010 | 11:41 PM
rotascircuit's Avatar
Default LOOK AT MY TIMING BELT AFTER 72MILES ON REBUILD
Hey Its my 95 gsr I did a little rebuild on after misshift. I put back the my used but OEM honda timing belt.
I got a new one just couple days after rebuild but this is what I found out when I took off the valve cover. I drove the car for only 72 miles.
Dont ask just look at pictures lol
Old Jan 15, 2010 | 11:45 PM
integra_101's Avatar
Default Re: LOOK AT MY TIMING BELT AFTER 72MILES ON REBUILD
I advise you VERY STRONGLY. DO NOT drive that car until that belt is changed.
I cant tell you what it is, but I know that it will rip soon. And you dont want that.
Old Jan 16, 2010 | 12:08 AM
as stated in my post I got a new belt. this is a picture when it was open cuz I wanted to change the belt and GOOD THING I am doing it NOW.
so what is it??
Old Jan 16, 2010 | 09:56 PM
TheAsian's Avatar
It is probably rubbing the timing cover check all the bolts and make sure the cover seats properly
Old Jan 16, 2010 | 10:21 PM
dc2b20v's Avatar
yeah i say its rubbing on somthing, what kind of rebuild did you do, just the head? did you take off the bottom covers? maybe you dropped something in the bottom covers
Old Jan 17, 2010 | 07:12 AM
MrD33Ds's Avatar
I had that happen to me on my old DA. My lower timing belt cover was off a bit. Simple fix. I'm glad you found it before anything bad happen. Timing belt<Rebuild (As you know lawl) GL.
Old Jan 17, 2010 | 01:03 PM
keepinitrehaal's Avatar
Looks like you caught it just in time.
Old Jan 17, 2010 | 01:29 PM
nebraskaimport's Avatar
must of been a missed lined cover i always check to make sure everything is just the same as when i removed it the last thing you want to do is valve check your motor also torque your cover bolts that could cause that to over tightening they torque to 10lbs
Old Jan 17, 2010 | 02:59 PM
nick3538's Avatar
yea, more info on what kind of rebuild you did.
Old Jan 17, 2010 | 09:56 PM
a mis shift from 3rd to 2nd and bent all exhaust valves.
I changed the valves and put good used gsr valves in. Got them seated it. I also changed out the piston rings. I changed the head gasket and intake mani gasket, timing belt, and adjusted the valves. I also honed out he cylinder walls to give it fresh cross marks.
why... are you planning to do something? its very easy once you get into it.
Old Jan 17, 2010 | 09:59 PM
I'll post pictures of why this happened on the main forum.
rotascircuit
Jan 16, 2010 06:11 PM
AnAccordIsForever
Mar 12, 2007 02:55 PM
ShinobiLude
Feb 15, 2007 09:03 AM
uncleben
Dec 23, 2002 12:25 PM
GasHuffer
Aug 5, 2002 12:06 PM
