Clutch line no pressure !!! please help
Okay guys well im stuck here and can't get any pressure out of my clutch. i did a Auto to manual conversion and got a new Master cylinder and slave cylinder and there is still not enought pressure to move the fork far enought to engage. instead of using the rubber oem clutch hose in between of the slave cylinder and master cilinder i made a custom metal hose, Not sure if that little hose can be causing the problem, i tried bleeding it numerous times and nothing, not enought pressure... can anyone help???
