Accord wont move please HELP
Old Jan 15, 2010 | 04:09 PM
srkdrift's Avatar
Default Accord wont move please HELP
Alright thanks for reading I have two accords and one was wrecked and the other had no motor. So heres the thing I swapped my 96 motor into my new 94 accord. Now when i crank it up it is in limp mode and will not go even when the car is in 1st it is a 5 speed f22b1 with a p2a5 stock lx trans. The clutch i had inside was going bad so i changes over from the new car with the blown motor clutch, pressure plate, and through out bearing all were good because the came with a bad motor with two rods broken but i drove the car into the garage. Everything is in properly i'm pretty sure about it. I have no idea what could be causing the problem please help!!!!!!!!!!!!!
Old Jan 15, 2010 | 04:12 PM
AlmostJDM's Avatar
Default Re: Accord wont move please HELP
did you use the 94 engine harness on the other engine? also did you use all the sensors off the 94 engine?
Old Jan 15, 2010 | 04:18 PM
srkdrift's Avatar
i converted it to odb1 so i can us my hondata i used all sensors from the 94 and my motor witch is out of the 96 and it is a f22b1 vtec
Old Jan 15, 2010 | 04:21 PM
AlmostJDM's Avatar
what code(s) is it giving you?
Old Jan 15, 2010 | 04:23 PM
jdmwannabee's Avatar
limp mode? what CEL are you getting? are the axles all the way in?
Old Jan 15, 2010 | 04:26 PM
srkdrift's Avatar
to tell the truth i have never owned a odb1 car so i don't even know how to pull the code but i'm not really worried about the limp mode i'm worried because i cant drive and it is my daily driver
Old Jan 15, 2010 | 04:34 PM
AlmostJDM's Avatar
thier is a 2 pin connector by the passanger kick panel right under the glove box, jump the 2 terminals together and turn the key to acc. and the cel will flash, long blinks are 10's short blinks are 1's so say you got __ _ _ thats 12
jarroyo84
Oct 15, 2012 05:25 AM
Atheist
Mar 16, 2007 08:16 AM
85vdub
Sep 19, 2005 09:04 PM
jc_freak
Sep 13, 2004 10:16 AM
