Leaking brake fluid.
I have a 99 Honda Accord LX. I noticed I was leaking brake fluid because I had to keep adding it. Well I finally went to track the leak down and I found that it is leaking from the piston of the caliber. Now my question is, is there a seal that I can replace, or do I have to buy a whole new caliber? Will any 98-02 caliber fit if I go the route of purchasing a used one? Thank you in advance.
not sure if you can replace the seal. any 98-02 caliper will fit as long as it is not from an EX or a wagon model. both of those have bigger calipers i think. (the EX may be the same size but came standard with 4 wheel disk brakes? theres a difference but i cant remember it for sure)
joe6
Mar 20, 2011 07:39 PM
