what head and cams
What head and cams should I put on a b16a engine? im shooting for around 200horse on it (with a head and other parts) and im new to the Honda side of things. What is some recomended places for parts?
for 200HP..on a B16? You'll need PCT pistons for more power... Bored TB and ITR or Skunk IM, then add aggressive cams ( Skunk stage 3, JUN 3, TODA C,) for higher flow. But since this engines and those cams make power on top of the power band.. you'll need to raise the rev...... so add Ti retainers, inner outer springs for safety. Of course you'll need to tune the ECU as well.. so Hondata or stock ECU modification is needed. Of course this you'll need the basics, I/H/E. And to complete the flow.. might as well do headwork too. I say about 5K later after all those parts and labor.. you should be close. Or.. just slap on a Garrett t4..
