How is my exhaust going to bolt up w/my engine??? I am stumped big time..
Old Sep 4, 2002 | 02:24 PM
Nameless RB26's Avatar
Default Exhaust problem (B18c5 into 99 Civic hatch) FUG!
I have a 99 DX hatch. There is NO catalytic converter on my car. It's just not on the D16y7.
Ok, I haven't done the swap yet, but I did bolt my exhaust system on already. (tanabe race medalion - hatchback model). When I swap my JDM B18c5 into this car, will the header bolt right up to the exhaust with no cat? Or is there going to be a gap where there needs to be one? I know I need a 2.5" flange somewhere too..
I have a testpipe for the civic (testpipes.com), but the part which bolts up to the beginning of the B-pipe has a 3 hole bolt piece. The B-pipe for the d16y7 has a two hole bolt piece..so this testpipe would be useless. I didn't do my research on this so I am trying to figure out how others have done it with a Type R engine into a 6 gen hatch.
Can't compare a GSR swap to this, because the GSR header is a different length. However, I read that the GSR header would bolt right up to a catback exhaust system made for this hatch (with no cat)... if that is true, then the Type R header won't. What do I do???
PLEASE PLEASE help me out with this. If you have experience with this EXACT swap, and if you used a cat-back exhaust system for the hatch, please tell me what to do here..
I am stummmped as a ************.
Thanks-
[Modified by Nameless, 6:32 PM 9/4/2002]
Old Sep 4, 2002 | 03:29 PM
salbaje's Avatar
Default Re: How is my exhaust going to bolt up w/my engine??? I am stumped big time.. (Nameless)
get a catalytic converter and use ex piping.
Old Sep 4, 2002 | 03:38 PM
Default Re: How is my exhaust going to bolt up w/my engine??? I am stumped big time.. (salbaje)
You gotta be more clear about that.
A catalytic converter for the Type R? Are you saying I should use an EX B-pipe? EX piping won't work..
This is a Type R engine, not an EX engine. The piping will need to be 2.5" for my setup..therefor I need to use my piping that came with my exhaust.
[Modified by Nameless, 5:38 PM 9/4/2002]
Old Sep 4, 2002 | 04:40 PM
someone here has to be able to help me....
Old Sep 4, 2002 | 05:30 PM
Default Re: How is my exhaust going to bolt up w/my engine??? I am stumped big time.. (TYPE EG6)
Yah, that's what it looks like in the helms manual.
The JDM ITR header is one piece.. so I have to figure out a way to hook this up to my tanabe system.
I am guessing there will be a gap between the beginning of the B-pipe and the header collector. But I can't figure out if it will be big enough to use a Type R cat or not...
****. I know someone on this board has done this swap. Someone out there can shine a light on this situation.
Old Sep 4, 2002 | 06:53 PM
maskednegator's Avatar
flex pipe, y0.
Old Sep 4, 2002 | 08:30 PM
CzanSOHC's Avatar
Default Re: How is my exhaust going to bolt up w/my engine??? I am stumped big time.. (maskednegator)
It is located in your exhaust manifold.
just have a muffler shop do some custem bends when you get your motor, get a hgh flow cat and relocate it. simple.
[Modified by CzanSOHC, 5:32 AM 9/5/2002]
[Modified by CzanSOHC, 5:39 AM 9/5/2002]
ramonjones16
Aug 4, 2009 09:14 AM
hmtcrxsir
Mar 10, 2007 09:59 PM
Ricey McRicerton
Oct 30, 2003 06:33 AM
Nameless RB26
Sep 6, 2002 03:15 PM
navin
Jul 8, 2002 12:17 PM
