BRAKE LIGHTS ARE NOT LIGHTING UP??????
Old Jan 14, 2010 | 01:14 PM
804tuned's Avatar
Default BRAKE LIGHTS ARE NOT LIGHTING UP??????
ok so i checked the backlight fuse,the brake sensor was changed,and i checked the bulbs...but my brake lights still dont light up....WHY????
am i missing something? thanx 804
Old Jan 14, 2010 | 05:17 PM
dc2much's Avatar
Default Re: BRAKE LIGHTS ARE NOT LIGHTING UP??????
taillights work?
Old Jan 14, 2010 | 05:19 PM
TunerN00b's Avatar
Checked for power at the brake switch?
Verified continuity of the wire from the switch to the lamp assembly?
Checked grounds?
Old Jan 14, 2010 | 05:44 PM
DJYoshaBYD's Avatar
Checked grounds?
for real.. anytime you have issues like this, you always check from the device you are activating, all the way to whatever switch activates it.. doesnt matter what it is..
take a volt meter, and have someone press the brake pedal down.. check for voltage at the bulb connector...
if you have no power there.. then check ALL your fuses in your car, just for safe measure, checking the light fuses first...
if all the fuses are good, check the brake switch..
if that is good, then you need to do a continuity test on the wiring, and find where the brake in the wiring is...
Old Jan 14, 2010 | 07:50 PM
804tuned's Avatar
i havn't checked the grounds or the break in the wiring...i gotta check those tommorow ..thanx 4 the knowledge guyz...
TomCurllyFry
Mar 25, 2013 09:29 PM
ihonda
21
May 31, 2012 09:53 AM
EGKevin209
Jun 22, 2010 12:41 PM
joey8099
Jun 2, 2008 04:04 AM
musclehead954
Feb 27, 2008 10:28 AM
