skunk2/blox tuner 1 or tuner 2? stock bottem end
Old Jan 14, 2010 | 09:39 AM
turbojdmsol's Avatar
Default skunk2/blox tuner 1 or tuner 2? stock bottem end
so im trying to get the most out of my setup and ive been piecing together a build that will put me around 190whp or better. I have an ALL stock bottom end on my oem 10.6 compression jdm gsr. I want to keep the red line around 8200-8500.
Which cams would be best for this build? tuner 1 or tuner 2?
heres my specs so far:
10.6:1 stock bottom end JDM GSR
blox dual valve springs
BC chromoly retainers
65mm professional products throttle body port matched to my intake
skunk2 tuner series adjustable cam gears
skunk2 pro intake manifold
aem highflow fuel rail
h22a4 injectors, they flow around 310cc
aem ITR 3" cold air intake
hytech tri-y header to a magnaflow resonator with complete 2.5" piping and no cat
walboro 255
and an awesome local tuner
this is my DD. Which cams would you recommend?
THANKS FOR ANY AND ALL HELP!
Old Jan 14, 2010 | 05:13 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: skunk2/blox tuner 1 or tuner 2? stock bottem end
tuner 2's.
Old Jan 14, 2010 | 05:17 PM
thanks for your input!
reasoning why?
other opinions?
thanks!!!!!!!
Old Jan 14, 2010 | 05:19 PM
00Red_SiR's Avatar
All Motor Mentor
reasoning why?
With your motor and the power level you want to achieve, the tuner 2's are what you'll need. The tuner 1's won't get the job done.
Old Jan 15, 2010 | 07:09 AM
thanks
others?
Old Jan 16, 2010 | 12:57 PM
would like some more info from other members...
Old Jan 16, 2010 | 01:03 PM
1.5Slowmatic's Avatar
out of what you have listed like was said before, tuner 2's.
Old Jan 16, 2010 | 01:51 PM
cool
Old Jan 16, 2010 | 02:22 PM
Slow_import's Avatar
if i remember right, tuner 1's normally only net like 170-180 on oem bottom end gsr's, and tuner 2's 180-190's. But i guess its really all in your tune and what kind of dyno you use, in some of the dyno thread's in here, there were guys making 200ish with tuner 1's but i believe they had itr pistons.
Old Jan 16, 2010 | 04:38 PM
^cool, thanks for the info!
Old Jan 17, 2010 | 10:09 AM
bump
Old Jan 17, 2010 | 12:56 PM
luispizarro25's Avatar
like it alot... so with this setup you can reach 190? how much can you reach now without the cams?
Old Jan 17, 2010 | 02:44 PM
im not too sure to say, but i know the cams will benifit me a lot
b20vtecGSR
Oct 28, 2016 05:27 AM
Josh.JD
Aug 11, 2011 10:41 AM
martyball619
May 21, 2010 03:31 PM
sleepycivix
Dec 18, 2002 08:30 PM
sleepycivix
Dec 18, 2002 04:53 PM
