big difference? b16/ctr piston
i just got done with my b20vtec got it all together found it there was a rod knoc now im using my own ls block to go lsvtec.
found some piston on craigslist
b16 piston = 120 usded but still good conditions
ctr piston new in box for 200..
should i save or spend 80 bux more??
It's been five minutes at 2:40 in the morning.
You probably won't get an answer any way. I can come up with 2 sections where this post would be appropriate.
GDD is not one of them.
Welcome to /40/
Welcome to /40/
Derail time.
I drove up to Denton today to pick up a hard top.
Turns out the place only sells parts imported from Japan.
Now I have a JDM hard top and JDM tail lights.
Both of which are the same as USDM.
okay but i have a legit question now because ive read about three different answers online. will a ITR timing belt work on a CTR engine?
and yes, i know what happens when one assumes, but i didnt make an *** out of you. only me. failure on reading comprehension.
I'm the only one that makes an *** out of myself.
How old are you first of all?
First mistake was to post this in GDD.
There is a tech forum, just saying.
And seeing your from California, don't do it. Simple as that.
If you're smart about it don't ask and learn.
Put all that **** into your car and see what happen, problem solve.
I'mma leave this to GDD.
