Transmission & Drivetrain Gearboxes, Differentials, Clutches
D series Trans question
Old Jan 13, 2010 | 06:41 PM
1991civicsi's Avatar
Default D series Trans question
Ive posted this question on another forum, but havent gotten any answer.
After changing the bearings and seals on my SOHC trans, I followed the Helm manual to measure for the mainshaft shim.
Helm instructions are to take two seperate readings and follow the formula:
B + C - 0.95 = shim thickness.
To determine factor "B" in the equation, the following must be installed onto the mainshaft as shown in my pic.
Thrust washer
3rd/4th Synchro Hub
Spacer Collar
5th Synchro Hub
Bearing
After the shim and oil guide plate are removed, the shaft is installed back into the housing.
A measurement is taken from the housing and the thrust washer.
The distance for "B" is Zero
The next factor is "C", and this is what we need to measure:
The measurement for "C" is 1.11mm
So the formula is A+B - 0.95 = shim size, right?
0 + 1.11 - 0.95 = 0.16mm
or
Another formula is : A+B - 1.06 = Max shim size and A+B - 1.13 = Min shim size
This formula would total:
0+1.11 - 1.06 = .05 and 0+ 1.11 - 1.13 = -.02
The only problem is there is no shim size less the 0.60mm, and the factory installed shim size is 1.00mm.
I have no idea what I am doing wrong. If you have any suggestions I would appreciate hearing them. TIA
tepid1
Jun 23, 2012 10:51 AM
92hatchboi
Oct 9, 2007 05:53 PM
hugegastros
Sep 6, 2007 04:06 PM
denshu
Jul 3, 2003 01:50 PM
