Transmission & Drivetrain Gearboxes, Differentials, Clutches
ring gears?
Old Jan 13, 2010 | 03:54 PM
t3601's Avatar
Default ring gears?
does anyone know how many teeth are on what ring gears? It has been a while since i dicked around with differents tranny's. So if anyone know how may teeth are on the b16, gsr, ls, if jdm tranny's are different. I tried the faq's but couldn't find anything
Old Jan 14, 2010 | 11:23 AM
t3601's Avatar
Default Re: ring gears?
somebody has to know how many teeth are on what ring gears.
Old Jan 15, 2010 | 06:17 PM
Mista Bone's Avatar
D Tranny Guru
I know, Bense knows, others know as well, it has been posted before.
Or you could just do the math....not hard.
Old Jan 18, 2010 | 11:53 AM
t3601's Avatar
so here is what I found out. if i'm wrong please correct me.
B16 has 66 teeth/final drive 4.40
GSR has 66 teeth/final drive 4.40
ls has 64 teeth/final drive 4.26
the counter shafts all have 15 teeth on them but are different in diameter size.
LIKE I SAID, IF ANY OF THIS IS WRONG PLEASE CORRECT ME...
Old Jan 19, 2010 | 01:01 AM
Mista Bone's Avatar
D Tranny Guru
what is the issue?
Old Jan 19, 2010 | 04:48 PM
t3601's Avatar
^^^^ the issue is that I was givin 3 tranny's dissasembled in a box. tryin to piece them together. kid I got it from thought he knew what he was doing and couldn't figure out how to put them back together. I'm using 1-4 b16, and ls 5th, so I'm using the b16 counter shaft and main shaft and needed to know which ring gear is for the b16 counter shaft. but I already figured it out and it works great. first time nobody on here could help.
96ekb20
Feb 9, 2016 06:28 PM
ZCHondaCRX91
16
Sep 3, 2015 07:00 AM
nycjdmwhore
Aug 15, 2010 03:29 PM
WhiteEKgsr
Dec 12, 2008 06:45 PM
boostedblue
Sep 14, 2005 02:43 PM
