Problem after clipping J1 jumper...
Old Jan 13, 2010 | 05:29 AM
rhoades's Avatar
Default Problem after clipping J1 jumper...
Stock D16 engine, P28 w spoon chip.
I wanted to revert the ecu to stock so per instructions on here I simply cut the J1 jumper.
Now the car idles @ 1100 and when the foot brake is aplied the idle jumps up and down to 1600 rpms. Once I release the brake it settles back down after a few seconds.
Other than that the car performs as stock. No check engine lights.
Any suggestions on what could be wrong?
Old Jan 13, 2010 | 07:56 AM
Relic1's Avatar
Default Re: Problem after clipping J1 jumper...
engine is a stock D16??
the P28 is designed for the stock Z6, any other engine or other changes to the engine will result in lesss than desirable results.
BTW, everytime I hear "spoon chip" my brain twitches.
Unless you purchased the ECU from spoon directly (and they had your car to tune it) it's not a spoon chip. It's likely a super crappy set of maps that runs way too much fuel.
Old Jan 13, 2010 | 08:08 AM
rhoades's Avatar
Ok. Thanks for replying.
It is a z6 engine.
also the chip has spoons label on it, so I am to assume it has a spoon chip.
Regardless of the tune the J1 jumper is cut so my issue is happening on stock tune.
Old Jan 13, 2010 | 02:10 PM
Relic1's Avatar
this will sound odd, but which P28 is it?
if it really is a spoon chip, then it's highly possible that the P28 you have doesn't have MCU code in it. (stock maps in the ECU)
reason - spoon and mugen received special ECUs from honda to make into their race ECUs, so no stock maps were needed.
what are the numbers on the tag 37820-P28-???
also the three digit number on the MCU, the large black chip above the spoon chip.
zrickety
Jan 27, 2009 12:12 PM
downpiped
Jul 13, 2006 05:43 AM
machine4321
Jan 18, 2005 07:24 PM
