Axle removal?
Old Jan 12, 2010 | 08:09 PM
So krazieY's Avatar
Default Axle removal?
How do you remove the axles on a rsx? Any pointer to lead me into the right direction.
Old Jan 12, 2010 | 08:14 PM
prejdmlude's Avatar
Default Re: Axle removal?
remove brake components, remove bolts to struts, step down on lca, tap out the axle from that side, then once out hit the axle out from half shaft and its out for driver side use pry bar to remvoe from tranny..to lazy to write more in details..
Old Jan 13, 2010 | 11:07 AM
So krazieY's Avatar
Thanks, anymore pointers?
Old Jan 15, 2010 | 04:56 AM
beavis's Avatar
Make sure you un bolt the abs sensor, people forget to do that alot and rip the wire out of it and its expensive to fix
Old Jan 25, 2010 | 08:32 PM
DC5DC2's Avatar
did any one ever have any problems removing the axle from the half shaft? any pointers
ExpeditiousRacing
Honda CR-V & Element
Feb 25, 2011 02:28 PM
Tommy_Gunns
Apr 13, 2009 09:39 PM
flaxx0r
28
Dec 29, 2008 07:15 AM
djSALIX
Apr 12, 2006 09:20 PM
huepowered
Mar 27, 2006 12:33 PM
