itr cams on stock b16 valvetrain??
i know this subject been brought up before but i couldnt find anything
was wondering if i can run the itr cams on a stock b16 valvetrain??
if not can i get some details?
I stated before that you could but was quickly corrected. It would be unsafe to do so. If you're going to upgrade cams, upgrade valvetrain
That is exactly what I said. Someone posted the a picture with the differences between the different valve springs. Explained how the b16 springs are more prone to binding and so on. If you can't afford aftermarket, find some used ITR springs
b16 redline is not 8500rpm, im running 00 ITR cams on my stock gsr valvetrain for a year and a half now, i havent had any problems so far
not familiar with b16 valvetrain but if you do put them in keep it in 8100rpm. i take mine to 8500rpm i guess its jsut my luck according to everyone, yet i wasnt the first to run itr cams with a stock valvetrain
i c haha, cool
imma put them in and stay under 8200rpm or so
thanks to all that gave me info
you will be safe with them just dont rev over the b16 rev limit. i got 2001 itr cams on my b16 and got it tuned on crome redlining at 8,300 and my motor is still fine. have it for 6 months now.
^^, doh* with itr cams you MIGHT be fine, but to be safe you might atleast need itr valvetrain.
or just run it to see what happens
gsr intake side is the same as older itr intake. some people run gsr on both ex and in. they are dual springs. i also had a friend run ctrs on stock springs and didn't have a problem. Just dont miss shift.
Thats not whats being said here. Its been stated that with ITR cams, one would be ok with the stock springs if the rev limiter was kept to the stock point... of which I would agree... now if you wanted to run something like say stage one cams, I would say you would need the ITR springs. If you wanted stage 2's or greater then its time to look into aftermarket springs.
And PLEASE don't tell me you are one of Rockets old minions. He can do all the "tests" he wants. The guy might know a thing or two but I would take it with three grains of salt and then still research the hell out of it before I believe anything more from his mouth. The stock B16A intake springs are the SAME as the ITR springs. Move them to the exhaust side on the B16 and get the ITR intakes if it really worries you. He can test all he wants, people have run these cams on stock valvetrain for years without issue.
lol i ran Itr cams in my b16 and reved it passed 10,000 plenty of times and had no problems at all.
motor finally popped when i ran alot of nitrous threw it :D
Wrong, you do not know how to design a spring. If you did, you would know lift is the controlling factor.
Further, itr and b16 are not the same springs. Again, you need to look up the data and the parts.
