Cam choices... Which one?
Old Jan 12, 2010 | 02:22 PM
civic2slo's Avatar
Default Cam choices... Which one?
Currently I running Type R camshafts in my setup. I was wondering if I should go with Skunk2 stage 2 or 3? Or Skunk2 Pro 1's. Also does the stage 3 have coil bind/clearence issues? The engine is currently in the car I just want to run 12's before I pull it for a rebuild or engine upgrade.
Specs are:
B16A with B17A crank/rods and CTR pistons (bought the short block that way)
Type R head (Toda valve springs/Skunk2 retainers)
Skunk2 IM with 65mm t/b
Stock Type R exhaust manifold
Just bought a Skunk2 60mm cat-back (Too loud for me. Waste of nearly $500.). Just seeing if it will help me with a tenth of two.
Since some cams work better on 1.8L than 1.6/1.7L. Just wondering which camshaft would more suit the displacement of my engine.
Old Jan 12, 2010 | 02:52 PM
Natural Aspirations's Avatar
Default Re: Cam choices... Which one?
IMO your going to have a tough time getting into the 12's on your current shortblock.
Although your current times are impressive, I am not sure a cam swap will get you 4 tenths. All of the Skunk cams you have listed have been used in 1.6 with great success, with the stage 3 being a great drag cam.
Any cam upgrade is going to need extensive clearancing with the CTR pistons as they are known to have problems with larger cams.
Old Jan 12, 2010 | 04:30 PM
Top Ramen's Avatar
You are going to need springs to go much bigger than the ITRs. And, anything with really high lift may cause clearance issues with the domes on those slugs, so be ready to clay it.
You could probably get away with BC3+ cams, if you don't move them around too much.
Old Jan 12, 2010 | 04:50 PM
civic2slo's Avatar
I had pro 1's but got rid of them because I was worried of clearence issues. I can get them back. though. The car is not really set up for drag. The car was being setup for auto x. Just for fun not for competition. So I have swaybars front (GSR) and back (ITR). I forgot to mention it has a 8lb flywheel which I assume that is hurting me of the line. The fastest the car ran is 13.29 e.t. with slicks and 2 1/4 piping to a 2in ES Oval muffler. The spare tire was out. I also took out the front passenger seat since I had about 7 gallons of gas in the tank. I figured that about right for the weight difference. If this was a drag car then I would of not put the sway bars, taken out the a/c system, not put on 5 lug suspension, misc items and would of made the car about 125-150lbs lighter.
With the 2in ES Oval muffler and the 2 1/2" exhaust with header it was 2 tenth difference in the 1/4 mile (14.0 vs 13.8). With lighter rims. I have stock 15" Type R wheels (35-36lbs with tire). Put back the Hytech header and cams swap. Swap the GSR tranny for an ITR one. I should be 13-13.1's or hopefully high 12's
Old Jan 12, 2010 | 04:54 PM
civic2slo's Avatar
Originally Posted by Top Ramen
You are going to need springs to go much bigger than the ITRs. .
I have Toda valvesprings. they were chosen because I could run stock cams without scarring them up and then run aftermarket ones later.
Had BC3+ in my engine for 2 days didn't get to track it. Someone made a stupid offer to me I couldn't refuse. So the BC3+ are gone lol. Move them around?
Old Jan 12, 2010 | 05:11 PM
I really wouldn't trust any cam with the combination you have without having the head off to check clearances.
What are you tuning your car with?
Old Jan 12, 2010 | 05:26 PM
civic2slo's Avatar
I had made an appointment to have my car tune, they had priority on another car. Another time they took to long on another car waited 3 hours just for them to say sorry could we do it another day? What a joke. Not going to mention the name of the shop. So just a base map. I drove this engine around for 11 months with no specks or pitting on the spark plugs. Pinging on hot days. So if the engine goes next. LOL.
I going to try Parrish next (for tuning). Anything good or bad about them?
Old Jan 12, 2010 | 07:12 PM
Allmotor-R's Avatar
skunk 2 stage 2's i have them on my ITR motor freaking crazy power band at 5700+ 9000rpm i tryed many cams on my motor these made the most on mid to top end range .My comp is 11.1
Old Jan 13, 2010 | 10:19 PM
nielracing's Avatar
New User
hi guys,
I have a s2s2 cams and supertech valvespring and retainers on my CTR head. during valve clearance check/adjustment I noticed that there abrasions on the s2s2 lobes and my rocker arm also showed some abrasions (metal-metal contact).
has any of you experienced this?
thanks!
Old Jan 13, 2010 | 11:10 PM
95skunkedgsr's Avatar
Originally Posted by nielracing
hi guys,
thanks!
did you have everyhing lubed when doin the chech
Old Jan 16, 2010 | 09:05 PM
civic2slo's Avatar
Well thanks everyone for their advice/comments. I guess I will have to find another car since I was hit and run on the 13th.
Old Jan 17, 2010 | 09:12 AM
Hybrid96EK's Avatar
Where in nor cal are you located? Hit me up on PM regarding tuning your car please..
Old Jan 17, 2010 | 10:41 AM
civic2slo's Avatar
Sacramento
keepinitrehaal
Feb 18, 2010 07:48 PM
GABOCRX
Dec 23, 2008 08:34 AM
bootlegcivic
15
Dec 2, 2008 10:29 AM
.I.Need.Money.
43
Feb 27, 2007 09:59 PM
jcivicsib20
Jan 20, 2003 12:35 AM
