Need help with chosing parts for B20Vtec.
Hey HT
I piked up an b20b block yesterday for an steal pretty much. I hve been loking for one for a lil while now to build an CRVtec. I have alot of questions to ask you guys.
Here is my build list. I have been living in the "post ur all-motor stock sleeves b20vtec builds" and chosing parts. Now i ned some one to confirm the parts list before i start spending money on the right parts.
Block:
b20b ...........80$. Shuld i run stock bore 84mm or get it bored to 84.5mm..?
Of course theres gonna be tons of measurements made
itr 84 mm rs machined pistons..........Or spend 200 more and get CP pistons..?
SCAT b20 rods...........Has any one ran these...Ow will i be better of with stock rods?
b20 ARP rod bolts 8 mm, same ones that fit into d series rods...........
ARP head studs..........
ACL bearing kit.............
tranny:
Gsr tranny with obx lsd
Head:
B16 head with dual valve springs and ti retainers
new valve stem seals....
Blox 78-76mm TB
CTR cams or wich ever willl yield me more power with my set up
880cc injectors to run with e85
Fuel:
255LPH intank walbro
Exhaust: 2.5 inch with stock gsr Cat..maybe straight pipe
ECU:
Chipped P28, obd2 to obd1 skunk 2 conversion harness...Need more info on what will run my set up better.
Personal Goal: 220whp and what ever torque it yields me.
Ok now on with the questions.
Alot of people say that ACL bearings will not be good for what i need. dannyk20 said that unless i have green marked bearings in the block right now, the acl standards will be to tigh.
One of the connecting rods has green stamped bearings and the rest from what it apears to be have yelloow mark on the rest.
Green 1.501-1.498 mm 0.0591"- 0.0590"
Yellow 1.498-1.495 mm 0.0590"- 0.0589"
Took the crank out to see the main bearings.....#1 has red and all the rest have yellow marked bearings.......?
Block:
tranny:
Head:
Blox 78-76mm TB
Fuel:
ECU:
Hey HT
Block:
tranny:
Head:
Blox 78-76mm TB
Fuel:
ECU:
Block:
tranny:
Head:
Blox 78-76mm TB
Fuel:
ECU:
i made 209whp 128tq (i also made 215whp on it but tuned it down had problems with air fuel ratio) on 1.8l 11.1 comp ported head sk2 stage 2 cams stock intake manifold stock TB ,spoon header4-2-1 hondata s300 etc... i dont see a problem for you reaching 220
if you do 2l 12.1 comp and skunk2 stage 2's you will get wellover 220whp tq can be anywhere from 150-170 . i am building 2l with stroker 2.2 l with 12.1 and sk2 stg 3 cams with ITB's looking for 240+ on pump gas
ok my personal opinion is that you leave it 84mm and just sleeve it bc b20 sleeves suck ***. as far as pistons spend that extra 200 and be on safe and have reliable pistons such as mahle or cp pistons . i have scat rods with 12.1 comp pistons over 2 1/2 years and had no problem, even hydro locked the motor they didnt even bent!!!! my luck lol. as far as the cams for you money and to make crazy power i have guy that built me a motor and compared over 10 sets of diff cams on dyno (on the same motor) believe it or not Skunk 2 pro series cams came out on top for the money!They make power thur the whole climb and make more on top end! comparing to toda and that other cams. Hope this helps!!
The reason why i am chosing to get RS machined pistons is because people have and still run them and have gread results and make great power out of them. I know the saying "what you pay for is what you get" comes to mind butt they do work. Thanks for telling me about the SCAT rods. I plan on running them butt i still need more people to pitch in about these rods please.
hey yea I ran them in my 85mm setup and it worked great as a matter a fact still works great after 3 years of beating. I got 283whp but with your goal, you'll be better off using stock ones and invest in cams or tune
Thanks
Guys can you help me out with chosing the right bearings. Will standard ACL bearings be safe/reliable to run.
Thanks again
I got to call him and see ..i know for a fact to my knowledge blox cams , old skunks , todas ,toda vtec killer , crower and few more.. ill check and get back to you with exact info.Because when i was building my head i wanted top notch i mean there are drag racing cams with a lift you cant daily drive but street wise i seen a diff and whats unique about skunk's their tq level across the board is even it is not up and down like many cams and power brand just rising no drop hp..It can also be how u degree them i guess and a tuner..
Hey thanks for the help. This build is a build that will take me a year +/- to build and truying to keep it under 2.5$ grand with chosing parts wisely i guess. I will not sleve it because the power i am shoting for isnt enough to crack the sleves with a proper tune and and an good colling system.
and you will have built motor with no worries..
if you are on the budget get pistons(around 500-600 new) cams you can find them from 400-800 used or new even im talking skunks dont know on other and scat rods are like 350-470 that is right there 1700 and you still have $$left over for valves retainers etc.NOte: depending what cams you buy make sure u get a good valves and etc..on your head cuz it is very important dont mix toda valves supertech spring and skunk2 cams for example you wont last long. if you budget is 2.5$ then you can do the above or do more research but thats pretty much about it pistons,cams ,valvetrain and rods for 2200 ..
Thanks
Dang that is good to hear. Ure saying that the stock b20 rods will hold 220 whp DD for as long as the engine last if not a bit more. Wouldnt it be better to be in the safe side and invest like 300$ into some stronger rods IMO. Were can i order a set of them. Do you have a link to a website that sells them so i can save it for later on purposes. Oh and will i have to do any machining to fit them into the RS machine ITR pistons..?
Thanks
Thanks again
Thanks
Thanks again
save that money and invest in a nice set of cams. tune the motor properly too
Still no replys on running ACL bearings..?
You should run bearings that will give the desired clearance. If the ACLs will do that then you are fine.
Nah ill invest in some stronger rods just to be on the safe side. Will i have to machine the SCAT rods to fit the RS machine ITR pistons..?
My motor has like 60k miles after the build still running strong as can be. Still racing and beating evo's and sti's with stock rods. yea i'm not your dad to tell you were to spend your money. you can go machine a block out of a solid peice of alluminum and you will be totally safe and spend more than 10k on the build.
no point of hitting 9's. 8.5 is more than enough.
I will make a build tread for you guys.
stop asking to much get building and thats it. bearings is not the head breaking part of the build. Your not going to drive that thing for 10 years. Kat does not worry about bearings. good reliable tune and your safe. listen what ppl say,not " so are they good" "so are they good" " can anyone say" blah blah blah.
Noobs be slapping motors together and posting the builds here and are good. Your making it look like your building a 450whp car. Your not 220whp is nothing super big and can have some stock parts in it.
yea totally tru thanks bro measure it up and if its all good, and if its cool then just run it and your safe. worry about more important stuff
ok but you'll pay the machine shop to custom line it up
