dx - si conversion
ok some of you guys may have noticed that i was in need of a motor. Well i got a good deal on a dx motor for my crx. the problem is that i want the power of an si. my question is: What parts do i need to pull off of my si motor to make the dx motor MPFI???? and does it all bolt up??? basically i have an si motor and a dx motor and i want to make the dx motor run just like the si (MPFI), how do i do this??? thx
Guest
Posts: n/a
resistor box, complete si intake manifold (rail fpr injectors evac all sensors and coolant lines, tbody etc) si ecu, si dizzy or equivilant, HAS to be a obd0 7 pin dizzy not the 5 pin ones) and the dx to zc wiring diagram
[Modified by TorteX, 2:27 PM 9/4/2002]
i also have another question. My car originally came with the si motor because it's an si. If i put the dx motor into it do i still have to rewire something even if i put the si IM and fuel system on it??? thx
Guest
Posts: n/a
yeah youd have to wire it back to dx and use the dx ecu and get rid of the resistor box, dizzy and manifold. hybrid-perf.org (something) has the diagram
do the above if you want to use the stock dx motor w/ manifold. other wise you can do dx motor and si manifold and dizzy (same as wiring for the si motor)
[Modified by TorteX, 2:38 PM 9/4/2002]
so let me get this right. all i need to get this dx motor into my 89 crx si is:
-IM and fuel system onto dx motor
-dx motor
-si distributor
-si ecu
and if i put the dx motor in my car with the si IM and fuel system i won't need to rewire anything, right??? thx
-dx motor
-si distributor
-si ecu
Guest
Posts: n/a
-dx motor
-si distributor
-si ecu
-dx motor
-si distributor
-si ecu
simike
Aug 13, 2002 02:50 PM
