little bit of oil in intake manifold??? normal???
Old Jan 11, 2010 | 09:19 PM
QnzEP3's Avatar
Default little bit of oil in intake manifold??? normal???
Ok so I took my throttle body off and seen. A bit of oil in the intake manifold, I heard its normal for ep3s but I don't believe that to much, any1 have any insite?
Old Jan 12, 2010 | 05:37 AM
Gtimportfanatic's Avatar
Default Re: little bit of oil in intake manifold??? normal???
normal for any car dude.. thats wat comes from the breather
Old Jan 12, 2010 | 05:54 AM
turboteg2nv's Avatar
Install an in-line catch can if you want a cleaner plenum.
Old Jan 12, 2010 | 06:13 AM
iv's Avatar
iv
+1 on this
I did this and my intake manifold is pretty much oil free
Old Jan 12, 2010 | 06:52 AM
QnzEP3's Avatar
<--- still learning lol thanks a lot guys, its that I'm having an idle issue so I'll tryin 2 figure out wat the problem is, when I took the tb off the butterfly closed perfectly fine 2 me and was still clean from 4 months ago so i dk if that might b my issue, I cleaned the iacv, put my short ram intake back (had a cai) and did an idle relarn idk wat else it could be
Old Jan 12, 2010 | 11:58 AM
Have you checked for vacuum leaks?
Old Jan 12, 2010 | 12:47 PM
QnzEP3's Avatar
i heard about covering the tb, if the motor dies then theres no vacume leak correct
Old Jan 12, 2010 | 01:06 PM
I would just look for any disconnected hoses first and listen for hissing noises.
Old Jan 12, 2010 | 06:18 PM
QnzEP3's Avatar
iight i hear a slight hissing but coming from the passenger side by the mount on the left side of the intake manifold, no where near the intake wat about that be and its hissing for a few seconds then stops then starts then stops doesnt seem like a vacume leak tho i might be wrong
Old Jan 12, 2010 | 06:57 PM
kobeballer96's Avatar
normal man. if your really worried about it get a oil catch can
Old Jan 12, 2010 | 07:09 PM
green-'s Avatar
Duuude thats rough man, i had oil on the manifold once and my wheel spacers fell off
Old Jan 12, 2010 | 08:31 PM
QnzEP3's Avatar
O no ****?
And where would I put this oil catch can?
Old Jan 12, 2010 | 09:53 PM
mrharmonic's Avatar
you can mount the catch can almost any where as long as you have enough slack of the pipeing
Old Jan 13, 2010 | 04:40 AM
wtf are you talking about??
OP here's the basic catch can install, this is for B-series motors though.
http://www.c-speedracing.com/howto/c...n/catchcan.php
Old Jan 13, 2010 | 05:35 AM
Targa250R's Avatar
be professional
I had oil on the manifold once, it was bad news. I accidentally the whole thing.
Cashmoney061596
Aug 10, 2013 01:01 PM
accord99power
Dec 22, 2010 10:47 AM
Slow_import
Jan 16, 2010 11:20 AM
GsrTurboCRX88
Dec 11, 2006 06:05 PM
itr1244
Jun 21, 2002 11:59 AM
