how do you check if 97 CL has same part# as 94-97 accords?
Old Jan 11, 2010 | 06:16 PM
Charlie Moua's Avatar
Default how do you check if 97 CL has same part# as 94-97 accords?
The problem is that acura uses different part# than honda even if it's the identical item. (example: gaskets, bolts, belts, ect...)
My brothers 97 CL had a slight electrical fire(no flame just smoke) behind the dash. We took out most of the dash and some of the main dash harness is burnt up. There are not many CL in junkyards that I could go strip for plugs/harness but are several 94-97 accord at the junkyards.
Question:
If anyone can find out for me for FACT, is main DASH harness (the one that goes through firewall of each shock tower and plugs up the cluster/climate control, auto shifter) the same?
* cash incentive for those that provide good helpful info or part# ect....($5-10) lol
Old Jan 11, 2010 | 06:22 PM
b18cKoupe's Avatar
Default Re: how do you check if 97 CL has same part# as 94-97 accords?
It probably isnt identical due to the electronic climate control found on the cl. I did source my radio and flasher plugs off an accord for my 97 cl though. my best guess would be that the cluster pugs are the same, not sure.
Old Jan 11, 2010 | 07:04 PM
Okay this is what I found so far.
1997 accord 2dr auto non v6
http://www.hondaautomotiveparts.com/...5=WIRE+HARNESS
1997 cl 2dr auto non v6
http://www.acuraautomotiveparts.org/...s=&view=normal
I can't tell if it's just one part# or multiple.
For= the accord diagram. I think we need #13 $516.60
For the CL diagram I think it's #6 $719.84
hum.......
Old Jan 11, 2010 | 07:06 PM
TheMuffinMan's Avatar
He knows where you live!
The climate control is what's going to **** you up.
Accords all had analog while the CL had digital, I'm going to wager most of that stuff isn't going to swap over in the center section. The cluster, radio, etc should all work though.
Old Jan 11, 2010 | 07:24 PM
son of a B*~!@#&*&^%@ !!!
damn i hate by brothers car.
Thanks for all the help. I have a strong feeling he might have to fork over $700 for a new harness.
Old Jan 11, 2010 | 07:31 PM
b18cKoupe's Avatar
I find them in junkyards all the time on ebay, check it out. I'm always looking for a nice leather interior and i've seen more than a few cl's being parted out. If you can find one at a upull yard you'll get a good deal even though it'll be a pain in the ***.
Old Jan 12, 2010 | 04:41 AM
I also need the "turn signal harness"..... I'm pretty sure it's the same thing as the accord.
Nickmg555
Jun 29, 2020 08:32 AM
h22accord101
20
Jan 12, 2011 12:46 PM
SpoonRSX
Audio / Security / Video
Aug 5, 2003 05:27 PM
