car won't start - main relay?
Old Sep 4, 2002 | 09:41 AM
dumbchild's Avatar
Default car won't start - main relay?
did a search on Main relays because I thought that was the problem,
everyones problems seemed to be that their car would start intermittently.
when I turn the key my car makes a wierd noise from the location of the main relay under the dash. and won't start at all, the fuel won't prime, or the dash lights come on. BUT - if i disconnect the + battery cable and then immediately reconnect it - the car will start no problem. As well, when I try to turn my car alarm on, the beep noise it usually makes sounds wierd as if the battery is dying. I tested the battery and it is fine. does anyone have any suggestions?
Old Sep 4, 2002 | 09:48 AM
civbeater90's Avatar
Default Re: car won't start - main relay? (dumbchild)
check your batt terminals.
Old Sep 4, 2002 | 09:57 AM
dumbchild's Avatar
Default Re: car won't start - main relay? (civbeater90)
as in are they polished up - well connected? I beleive they are but I could try again...any other ideas.
Old Sep 4, 2002 | 10:38 AM
EightOhOne's Avatar
check the connections of your alarm and the little wires running to your battery terminal. My car had a problem of doing that as well as cutting out while driving, until i messed with the terminals. It turns out that a splice right near the terminal for one of the alarm ground wires was loose.
Old Sep 4, 2002 | 10:52 AM
dumbchild's Avatar
Default Re: car won't start - main relay? (EightOhOne)
good idea - I guess it could be my immobilizer on my alarm if the alarm wiring was loose. I'll check that as well.
Any other ideas anybody?
95civlx
Jan 24, 2011 06:18 AM
95civlx
Nov 23, 2010 05:47 AM
reno96teg
Apr 23, 2008 01:52 PM
amazinspiderman
Jul 20, 2007 01:06 PM
LOC714
Mar 8, 2006 12:57 PM
