Wheel bearings are going out on the sol, swap to rear discs now?
Old Jan 10, 2010 | 08:49 PM
H23_del_soul's Avatar
Default Wheel bearings are going out on the sol, swap to rear discs now?
Ok, the rear bearings sound like damn propellers.... it's bad. Now I'm stuck. Should I just replace them, or should I go ahead and do a rear disc swap? What all is required for the swap, and from what cars? Anyone selling a swap ATM? Where is the best place to get the bearings if thats what I go with? thanks in advance for all the answers guys
Old Jan 10, 2010 | 09:21 PM
Default Re: Wheel bearings are going out on the sol, swap to rear discs now?
also which rear wheel bearings should I go with, there are several different ones when I search. Anything in particular that I need to be looking for?
Old Jan 11, 2010 | 08:07 AM
come on guys, someone here has to know SOMETHING!
Old Jan 11, 2010 | 08:23 AM
itsnotfast's Avatar
Replace the wheel bearings, unless you have someone willing to sell you the rear disc swap real cheap. If you were to do the swap, I believe you would need the rear disc assembley, the proportioning valve, and im not sure if you need the master cylinder or not. If you're anywhere close to Delaware, I have 2 complete rear disc swaps. PM me if you're close and interested. It would be much easier and cheaper to replace the wheel bearings.
cjb92
Jan 26, 2010 02:17 PM
RaysBoomBoomLude
Jul 9, 2008 04:47 AM
redman223
Apr 30, 2007 02:36 PM
Steve91
Aug 26, 2002 02:51 PM
Padronis
Jun 23, 2001 07:12 PM
