Car shaking
I have a problem when running my car how faster i'm going the car begin shaking if i ran in a normal speed it won't do it.what can be the problem??the mounts are ok.also the balljoints?what can do that please help!!!
my cousin 240sx was doing the same thing his car was jerking/shaking his problem was the throttle sensor easy fix. his throttle sensor was tilted downward everytime he went normal speed his car would jerk he had new rotors brakes his alignment wasnt off. he bought an extra bolt cuz he was missing a bolt for his throttle sensor went to go test it out his car was running smooth again.
~ If it happens when your braking at a faster speed that indicates that you have a warped rotor or 2,
~ If it happens while driving faster and the wheel shimmy increases you need to balance out your wheels,check the thread on them and make sure theres no bubbles on the sidewall, if you find nothing on the tire. check if your alignment is right.. theres plenty of shops that do them for like 80 bucks..
~ if its accelerating off the dig then yea.. i agree with type r.. check all ur connections to the throttle body and make sure you have no leaks anywhere..
jus find out which 1 of these are closest to your problem..
OBDII Integra
Nov 3, 2007 03:59 PM
deucedeuceEK
Apr 27, 2007 02:39 PM
