how do i remove the front balance shaft bolt?
Old Jan 10, 2010 | 01:56 PM
dleccord's Avatar
Default how do i remove the front balance shaft bolt?
im trying to remove this bolt in the yellow? i want to replace the seal behind the shaft and the retainer.
Old Jan 10, 2010 | 02:21 PM
GhostAccord's Avatar
Default Re: how do i remove the front balance shaft bolt?
Stick a screwdriver shaft threw the maintenance hole located just behind the gear on the Balance shaft. In the image you provided, the maintenance hole is circled in red. This will give you leverage to keep the shaft from turning while you loosen the bolt.
Old Jan 10, 2010 | 03:07 PM
dleccord's Avatar
yeah i did this but it bent my screw driver. did you guys use anything else beside the screw driver?
btw, how much ft lb is that bolt tightened down?
Old Jan 10, 2010 | 03:23 PM
IIRC I used one of my 5-6" hardened steel Allen keys. The tq specs are 22 lbf-ft for the front and 18 lbf-ft for the rear.
Old Jan 10, 2010 | 03:33 PM
Mr.Burner's Avatar
if you have a 3/8 impact, that works to. or a strap wrench
Old Jan 10, 2010 | 03:35 PM
Conan's Avatar
I just did this yesterday. I bent the first screwdriver, cause I used a long one and tried to let it bind on something. So just use a regular screwdriver, stick it all the way into the hole and just hold onto the handle. You should be able to get it off, it isn't on very tight.
Raebranch
Jan 5, 2017 09:29 AM
1997 Odyssey LX
Oct 30, 2013 11:17 PM
trooper0641
Mar 4, 2008 12:55 PM
welfarepc
Feb 3, 2007 07:02 AM
hondaZvic
Jun 12, 2004 03:58 PM
