the better buy????
Old Jan 10, 2010 | 09:44 AM
feriotypeR's Avatar
Default the better buy????
would itbs OR stage 2 cams, dual springs, ti retainers be better? which would bring out more power?
Old Jan 10, 2010 | 12:25 PM
killerpenguin21's Avatar
Default Re: the better buy????
stop for a second, and ask yourself...
"did i give anyone enough information to answer my question?"
if you said no, you are correct.
plus itb's will not be the answer.
Old Jan 10, 2010 | 03:52 PM
feriotypeR's Avatar
ok, what would be the answer?
Old Jan 10, 2010 | 06:13 PM
...post what the heck your setup is.
and whose "stage 2" cams you are buying because they are all different.
Old Jan 10, 2010 | 07:10 PM
Top Ramen's Avatar
What's the best color?
Old Jan 10, 2010 | 07:27 PM
all-mtr-teg's Avatar
My gut tells me cams and a tune should be done first. ITB's won't do much on a motor with stock cams.
Old Jan 11, 2010 | 07:07 AM
Itbs are not a power adder anyway
Old Jan 11, 2010 | 08:05 AM
4piston's Avatar
Induction is one of the BIGGEST power makers on these motors. Both should make power if you size them properly for your motor. Plan ahead though. Sounds like you will eventually being doing both.
Digital_Freedom
K Series
Dec 17, 2015 07:41 AM
Civic*B16A3*Eg
Mar 3, 2007 02:02 PM
IMPATIENT
Feb 3, 2005 06:22 PM
tsjag17
Jul 13, 2001 06:21 PM
