SI gauge problem
ok i have this problem. long story short i have a 99 civic SI i took the cluster out and sanded the bak of the RPM gauge so wen u turn the lights on it becomes brighter wich looks very good btw. As i was about to do this i thought it was the 2 lil blak screws in the front u needed to remove then i removed the ones in the back of the cluster where its green. as i picked it up the lil mechanism in the bak moved around on me and moved the needle as well. now wen i put the key in the ignition and turn it jus so u can put the windows down and see the oil light and batter light etc. the needle on the rpm side moves up a little. its not suppose to move and stay at zero until i actually turn the car on. Is there A way i can reset this sum how bak to where its suppose to b at zero .
HELP PLEASE AND THX !!
live and learn,you just meesed your ish up.i never even heard of what you were trying to do. if you wanted brighter put led bulbs in.also you didnt need to touch the two black screws in front
really think so ? i kno bro i thought it was the two in front =X. the thing is ma cuzin did it to his ek9 and his boy did it to his si and it looks really good no need for leds bro . so like wa do i do =[ ??
ma boy found it but the thing is not alot of peaple did wa i did (sand the bak to make brighter)
and i made the mistake of takin the 2 lil blak screws off. the DIY i found was
how to take the cluster out and put new gauges in and needles etc......
