Suspension & Brakes Theory, alignment, spring rates....
In need of fittings ASAP for wire/hose tuck - Brake related
Old Jan 10, 2010 | 06:03 AM
B16A1-EF9's Avatar
Default In need of fittings ASAP for wire/hose tuck - Brake related
I'm currently trying to finish my EF build. I got my SONEM hydraulic adapter last week and finally mounted everything up. I'm trying to making the clutch hoses and also some brake hoses. The clutch master I have appears to be a 12mm thread. Can anyone tell me where I can get a 12mmX1.00 to -3AN fitting, I've looked everywhere and found nothing.
Old Jan 19, 2010 | 08:43 PM
dohcvtak's Avatar
Default Re: In need of fittings ASAP for wire/hose tuck - Brake related
bump
... im looking for something similar too for the master brake cylinder
http://www.purechoicemotorsports.com...rod/prd111.htm
http://www.pegasusautoracing.com/pro...asp?RecID=5935
im not sure if this will work..
but let me know if u have luck with it
Old Jan 20, 2010 | 05:57 AM
phunhaus's Avatar
Are you sure about that fitting size? What clutch MC are you using?
Corinthiano
12
Nov 19, 2014 05:59 AM
s13hero
Oct 13, 2010 02:33 PM
TopEndUSA
Feb 22, 2009 04:10 PM
Solscud007
Jan 13, 2006 04:44 PM
