Bent subframe repair w/pics. Safe?
Old Jan 9, 2010 | 06:05 PM
8OOSTED's Avatar
Default Bent subframe repair w/pics. Safe?
I hit a curb about a month ago and I have all the parts to fix it but the subframe is bent and I can't get hook up the LCA. I tried to bend it back as best as I could, but the left side (see pics) is still pushed back about a quarter inch. I can't think of anyway to pull out the frame besides putting it on a frame rack of couse, but I came up with another possible solution. I'm not sure if this is safe but tell me what you guys think. Instead of pulling out the frame, I figure I could drill a second hole (see pics) and weld up the original one. Also the hole wouldn't be in that exact spot, it will actually be moved up a little, if that matters. I could also fabricate a subframe brace for it but im not sure this is necessary or would even help support it. Do you think this would be safe? I can't think of any other way to fix besides replacing the subframe or taking it to a shop... which I don't have money for.
Old Jan 9, 2010 | 07:05 PM
92_DB2's Avatar
Default Re: Bent subframe repair w/pics. Safe?
since you can weld what i would do is go to a pull apart cut that secion of the subframe off and put it on your car that would be the correct way to fix it
Old Jan 9, 2010 | 10:06 PM
all-mtr-teg's Avatar
Why not grind the LCA bushing guide pin so it fits perfectly snug into the bent subframe? There's more than one way to skin a cat.
Old Jan 10, 2010 | 01:43 PM
8OOSTED's Avatar
Thanks, I didn't even think of that. I might not have enough meat on the guide pin to do that though.
Old Jan 11, 2010 | 04:13 PM
8OOSTED's Avatar
Trimming the guide pin and using a smaller bolt worked great, thanks for the idea man.
leelikeya
Honda S2000
12
Apr 20, 2013 02:46 PM
b16bri
Welding / Fabrication
11
Nov 4, 2011 01:35 PM
TurboCoop
25
Mar 26, 2007 09:31 AM
Hondogg
Jul 26, 2004 08:50 PM
Ross
Dec 4, 2001 08:58 AM
