Transmission & Drivetrain Gearboxes, Differentials, Clutches
b series trans/clutch problem help!!!
Old Jan 9, 2010 | 06:04 PM
01typer1124's Avatar
Default b series trans/clutch problem help!!!
this is wierd nd hard to explain. here's the problem the best i can explain. i had reved it up one day and dumped the clucth since i did this a month aho this problem has occured and the reaosn i havnt really driven my car. the pedal goes to the floor and wont disengage my clutch, if i pump it because it goes to the floor but comes back up just with no preasure. if i pump it and give it gas it wierd because theres not like some technique i can do for it to work it jus does or doesnt work somtimes, if i pump it rev it or whatever it will com back and work, but wierdly like the clutch will grab really low or fine, just wierd. heres another thign as im driving at a certain rpm like if im giving it gas at a certain rate it will work again with engaging and disengageing. if im driving and get off the gas the pedal is dead again with coming back up without disengaging or doing anything. but if i give it a 1/4 gas it will be able to disengage the luctch but not all the way like it should sometimes. another thing if im at a stop without pre disengaging the lcucth it wont go into gear, what i mean by that is if im driving and about to stop i gotta give it gas and do the tricks like give it a 1/4 gas and get it to i guess get some type of presure that alows it to disengage and then hold it down. then once i start off again it disapears again and i gotta paly with it in order to shift again. ots a real pain. heres another wierd thign which i found out if i come to a stop without preparing the cluctch again and it wont work, ill turn the car off and press the lcutch in once realease it nothing but as soon as i do that and push it in again the lucth gains the preasure back and is perfect everytime no playing with it or anything, just turn the car off push it in once release it push it in again and bam got the preasure back for it to work, turn the car on and put it in 1st and go but then have to do all this trick and b.s for it to shift and engage/disengage. i must have blown somethign when i reved it up and dumped the cluctch that one day. i checked for leaks and there isnt any spot that i can see with fluid around it but maybe it happens and elaks only when im driving idk. someone please help me out, i hope its not my clutch thanks. p.s. its a gsr trans and engine in a 2 door civic ej1 thanks
Old Jan 10, 2010 | 10:42 PM
Default Re: b series trans/clutch problem help!!!
anybody?
Old Jan 11, 2010 | 09:54 PM
Mista Bone's Avatar
D Tranny Guru
nobody can read your first post, why we haven't replied.
stuntssilvia
Nov 4, 2006 11:16 AM
ludee00
Mar 23, 2005 08:53 PM
eMpAtHy
Oct 14, 2004 11:31 PM
Malachi
Aug 29, 2002 06:39 PM
