99 fogs installed... but wont work!
i just finished installing some fog light i order off of ebay i figured i buy some an give them a tried well i finished wiring everything but they wont work
every time i turne the switch on for the fogs it lights up like if they were working but not the fogs this is my first time installing this fogs so a couple of pointers will help thanks guys if you need me to post pics up i will do just to get them working!
there is a plug under ur dash in ur fuse box that you need to have pluged in for the lights to come one it is a brown plug i believe
WELL I HAVE EVERYTHING PLUG IN YEAH I DO HAVE A BROWN PLUG PLUGGED IN INTO THE FUSE BOX UNDER THE DASH BUT IDK IF IT GOES THERE OR UNLESS I HAVE IT PLUGGED IN A WRONG PLACE?
Grab a tester and test the slot where u plugged in that brown plug from the fogs make sure its giving out power....if not try picking another slot......also, make sure ur fogs ground is well in contact....try finding a different spot for the ground...i had a similar problem where they wouldn't work and turned out it was a bad ground.
you think one of the fuses would of went out? and were exectly does the brown plug go into i know its the fuse box under the dash but witch one?
there are only like 3 or 4 slots that look exactly alike under your dash for for yout o plug it into it doesnt matter wich one you plug it into...make sure u have solid bare metal grounds and that its connected to the battery correctly and make sure u didnt damaga a wire during instilation to where its grounding it self out and wont turn on
fordnick3
14
Oct 22, 2009 12:17 AM
